6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
REGEN?? Please help
Old Jan 16, 2008 | 09:43 AM
cbch9003's Avatar
cbch9003
REGEN?? Please help
I am new to all this and I have seen some fourms that talk about their engines in "regen" can somebody explain to me what this is?? thanks
Old Jan 16, 2008 | 10:38 AM
origcharger's Avatar
origcharger
With few exceptions, 2007 diesel emission standards require a Diesel Particulate Filter in the exhaust system, regeneration is the process by which the DPF cleans its self similar to a self cleaning oven. This process sometimes needs extra fuel injected into the exhaust stream to accomplish.
Old Jan 16, 2008 | 10:49 AM
gravdggr's Avatar
gravdggr
The EPA has put new regulations on emissions for our vehicles. Therefore on the Ford the exhaust has an afterburner in the system that burns off any excess diesel particulates that don't burn up in normal operation. If you have a new diesel you will experience low fuel economy during this process. The regen process will also vary in frequency depending upon driving conditions. Usually takes mine about 30 minutes if sitting at idle. The idle will kick up to about 1200rpm. The more intown stop and go you do the more often it will regen. The truck will stay in this regen mode until it completes its cycle. (I have witnessed this first hand.) My driving is more stop and go so it has regened alot more than other people that I know that have them and drive on the hwy. I get crappy mileage at least I think I haven't gotten better than 12mpg on the hwy of course mine is still new and haven't road tested it yet. Other froends of mine get 16-18 hwy. Dealer says nothing is wrong with mine and every truck is different...they shouldn't be they are all made the same. Mine acutally started to dump smoke out the back in regen mode (which it's not suppoose to do) and the dealer still said nothing wrong with it. I have the 3.73 limited slip and auto tranny. If you have a new Ford watch the DVD they give you it'll tell you about the regen. If you haven't bought a diesel yet make sure you do your research. If you aren't hauling alot or on hte hwy all the time you might consider a gas engine. All new diesels do the regen Dodge is horrible I have heard.
Old Jan 16, 2008 | 11:43 AM
rmosso1's Avatar
rmosso1
CBCH9003:
As stated above, no big deal. I have almost 1000 miles on my F-350, 6.4 and I have not noticed the regen mode to date. It probably happened while I was driving as my short trips are over 10 miles. As gravdggr states, watch the CD that came with your truck a couple times and then you will be as smart as everyone.
Old Jan 16, 2008 | 12:39 PM
SANDDEMON08's Avatar
SANDDEMON08
Max or Ken should put this in the 6.4 tech file,sure is asked alot
07-4-11 6.4L DIESEL - REGENERATION FUNCTIONAL CHARACTERISTICS
Publication Date: February 20, 2007
FORD: 2008 F-Super Duty
ISSUE:
2008 F-Super Duty vehicles equipped with the 6.4L diesel engine are equipped with an oxidation catalytic converter (OC) and diesel particulate filter (DPF). The function and operation of these parts may cause some customers to perceive an issue with their vehicle.
ACTION:
Review the Operating Characteristics with the customer.
OPERATING CHARACTERISTICS
Diesel particulates in the exhaust are trapped by the DPF. Regeneration is the process by which exhaust temperatures are increased so the particulates are combusted.
The frequency and length of regeneration will fluctuate as both are determined by the drive cycle. For most drive conditions, regeneration frequency will vary from 100 - 600 miles (161 - 804 Km) between occurrence and last from 10 to 40 minutes. The first regeneration does not require 100 miles (161 Km) and may occur at any time. The length of regeneration is usually reduced if a constant speed above 30 MPH (48 Km/h) is maintained.
The following is a list of normal operation while the vehicle is in regeneration, and do not require repair. If you are not sure if the vehicle is in regeneration, IDS can be used to monitor the Diesel Particulate Filter (DPF) PID.
Engine idle speed can be 1100 to 1200 RPM in park/neutral with foot off brake.
High idle speed drops to within 50 RPM of normal idle when the brake pedal is touched, PRNDL is actuated, or clutch is actuated.
White smoke in cold ambients is normal and the amount will be increased during regeneration.
Powertrain power is limited to 325 horsepower (HP).
Engine responsiveness may be slightly different than normal operation.
During initiation of regeneration, exhaust smell may be noticed - especially on new vehicles.
Powertrain sound will be different including air induction noise (including flutter on deceleration or engine shut down), exhaust noise, and changes in engine radiated noise.
During regeneration, exhaust temperatures are elevated.
The following is also normal and may be observed by a technician using a diagnostic tool. It is not likely that a customer would be aware of these:
The throttle body is only active during the regeneration process and during shutdown.
EGR is not operating during regeneration.
WARRANTY STATUS:
Information Only
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
Old Jan 16, 2008 | 01:49 PM
richfaa's Avatar
richfaa
If you google Diesel particulate filter .you will learn all you need to know about the DPF
Old Jan 16, 2008 | 02:43 PM
rmosso1's Avatar
rmosso1
Arrow
Is there more information than that included in vivid color in the CD that FORD gave us when we made purchase of a new 2008 Ford with 6.4???????
