ignition problems
Old May 26, 2002 | 11:01 PM
mstoned1's Avatar
mstoned1
ignition problems
i have a 460 swapped into a 79 bronco the problem is when it is cranking it has power to the ignition and runs but when in the run position it dies out like someone pulled the wires off the coil i have switched starter relays ignition switches and duraspark modules and nothing has helped if any one has any suggestions they would be greately appreciated
mike hagen
79 bronco 460 and 3/4ton axles
96 f150 300 6 5speed eddie bauer:-X11
Old Jun 6, 2002 | 09:22 AM
vroom460's Avatar
vroom460
ignition problems
it runs when you hold the starter on like you are starting it but when you let off it it dies out right then you have a wire hooked up wrong i had this prob on a truck i built but i cant remember what it was maybe it was at the solinoid
Old Jun 8, 2002 | 03:11 PM
DeGideo's Avatar
DeGideo
ignition problems
Old Jun 8, 2002 | 04:57 PM
mstoned1's Avatar
mstoned1
ignition problems
well its a beater and i found out it will run good with a remote starter and leave the key in run but thanks for the suggestion
mike hagen
1996 f150
1979 bronco
bigboylk
1978 - 1996 Big Bronco
15
Nov 3, 2019 12:23 PM
Normspeed
Apr 14, 2014 04:51 PM
Thunderhorn
Feb 4, 2014 11:30 AM
HatleyT
Jul 6, 2012 11:40 AM
