Sponsored by: Auxito
Check Engine Light
Old Jan 15, 2008 | 07:33 PM
WENDOV's Avatar
WENDOV
Cool Check Engine Light
2000 F-150, 4.2 V6
Check Engine Light Is On. Have Disconnected And Reconnected The Battery Several Times To Re-cycle. Replaced The 2 Front O2 Sensors.
I Think The Codes Read By My Parts Store Were 172 And 173, Runnjing Lean On Banks 1 And 2?
Anyone Have Any Suggestions?
Old Jan 15, 2008 | 08:02 PM
bigdaddyII's Avatar
bigdaddyII
Had that code on my wifes Sentra. changed O2s and that didnt help. Ended up being MAF sensor.
Old Jan 15, 2008 | 08:21 PM
WENDOV's Avatar
WENDOV
Thanks Bigdaddy
Old Jan 15, 2008 | 09:48 PM
projectSHO89's Avatar
projectSHO89
Verify your fault codes. Those are not "lean" codes (which are almost never caused by O2 sensors).
MAF sensors can cause mixture problems, however, there are more common and less expensive to repair faults that are usually at issue.
Steve
Old Jan 15, 2008 | 10:19 PM
DGMFORD's Avatar
DGMFORD
I pulled a 173 once which ended up being a vacuum line that had developed a huge hole. Replaced, cleared code, problem resolved
Old Jan 16, 2008 | 05:23 AM
WENDOV's Avatar
WENDOV
Thanks Guys
Old Jan 20, 2008 | 10:28 AM
Fat Ford Boy's Avatar
Fat Ford Boy
Question
Just this week, I had the same exact codes come up.
Here's what I had.
I bought intot he "tornado" theory. I decided to take it out, and I did. NOW, I get these same codes. We did the removal of the battery post, and even went to the hand held computer and "reset" the thing. NOW it is back.
Is the maf dirty, or need replaced ???
Old Jan 20, 2008 | 11:55 AM
projectSHO89
Here's what I had.
Probably a leak in the intake tract since that's what you were messing with.
Steve
wes harmon
20
Jun 13, 2011 04:00 PM
cdc2_2004
1983 - 2012 Ranger & B-Series
Apr 28, 2009 06:43 PM
lovs2fly
Oct 4, 2006 10:49 PM
billyb
Feb 26, 2001 07:28 PM
reddogg
Feb 22, 2001 01:23 PM
