Fuel Pressure Question
Old Jan 16, 2008 | 11:51 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by 99SevenPoint3
what should a good fuel pump be putting out... i need to run a fuel guage because i think mine is also going down the drain...
There are several variables here. You must make sure the lines are clear and the filter is good. A good rule of thumb is right around 50-55 psi minimum at idle if all else is well. Since a problem with the stock pressure regulator spring can also lead to low psi, you must also be sure that is not an issue before targeting the pump. I had 57 stock and shimmed it to 68. It drops to about 58 at WOT now.
Old Jan 16, 2008 | 12:34 PM
white Buffalo's Avatar
white Buffalo
well if i can make it look nice enough i dont mind placing inside the truck to monitor it at all time ... but i dont have any type of ugprade fuel supply as of now its all stock. Ive read somewere on here u can just tap into the fuel bowl and get a reading from it but then agian im not certain of that ... if any member has pictures that would be great to take a look at
I installed DiPricol's fuel pressure guage on the windshield mount, here are a couple of pics. It definitley wasn't cheap, alot more than Mike & Brandons, but the guages are sweet and I like the setup. The sensor ties right into the fuel bowl. Easy install. Got it from ITP. www.itpdiesel.com.
Old Jan 16, 2008 | 01:19 PM
white Buffalo
Here are some pics of the sending unit tied into the fuel bowl. I bought the adapter from ITP diesl for $6. Here is the link.
http://www.itpdiesel.com/store.php?crn=104&rn=432&action=show_detail
The adapter screws into the fuel bowl and the sending unit into the adapter. Easy install.
edit: oopps! Ininitially I pasted the pics of the HPOP - let me fix... sorry!
Here we go., the correct pis,
Old Jan 16, 2008 | 01:46 PM
Tenn01PSD350
Man Rich, those really look good. I'm still trying to convince myself I don't need those.
Old Jan 16, 2008 | 01:54 PM
white Buffalo
I told myself I was done with the mods for a while, the Brandon posted the pics of the hitch lights under the bumper, I had to do that with all the camping. Then I had to have new brakes & rotors.
Man I gotta problem - I have to go see a doctor or something.
Old Jan 16, 2008 | 02:14 PM
Tenn01PSD350
Tell me about it. Well I don't need those backup lights either. Just gonna float down that big river in Egypt some more.
BobbyB
Nov 26, 2014 08:14 AM
ol_red92
Jul 8, 2014 03:38 PM
Bsnith
1983 - 2012 Ranger & B-Series
15
Jun 16, 2013 12:08 AM
Edogsf350
May 29, 2013 05:09 PM
cleanstreak
Apr 3, 2003 07:23 AM
