Spare engine to rebuild?
Old Jan 14, 2008 | 10:04 PM
52caddy's Avatar
52caddy
There's a guy selling a 7.3 here that was pulled out of a 93 F350. He said it was smoking a bit and that's why he changed it out, supposedly had around 140,000 miles on it when it was pulled. Sounds a little suspect to me.
I asked about SCAs and he never responded directly, so that leads me to my question. Is it possible to determine if there is any damage to the walls from cavitation without tearing it down, or do you have to get inside to see?
He's asking $300 for everything except the starter and alternator. Would this be worth it if the block turns out to be shot? I'd like to get one to rebuild over time as a side project to the other 20 or so I already have.
Thanks!
Old Jan 14, 2008 | 10:09 PM
catfish101's Avatar
catfish101
The only way to get any look is to knock out the block plugs or freeze plugs. You can take a small dental mirror and see what you can see. Thats is your only option.
Old Jan 14, 2008 | 10:28 PM
belandd's Avatar
belandd
Spare Engine
Can't you pressureize the block with air to look for leaks?
Old Jan 14, 2008 | 10:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If you can find an adapter to put air pressure into the glow plug hole, yes you can.
You also have to remove the rockers and fill the block with water.
After all that is done, put 150 PSI or so in each cylinder.
If the water level starts to rise, either a head gasket is blown, the block is cracked, a head is cracked or the block is cavitated.
Caution, when you do this the engine will rotate untill the cylinder is at bottom dead center.
Watch your fingers, toes and tools as this happens.
Pitcrw6
Sep 8, 2012 11:18 AM
Redneckryder
15
Nov 17, 2010 08:13 PM
just another truck
15
Feb 18, 2008 02:47 PM
78ford351m
19
Apr 10, 2006 10:19 AM
fernalddude
Bronco II
Feb 18, 2005 09:54 PM
