89' 460?
Old Jun 10, 2002 | 09:06 AM
wc3jp's Avatar
wc3jp
89' 460?
I'm in the market for a tow rig for my Jeep. The F250 I looked at yesterday made an odd sound after turning it off. A buzzing sound or maybe pressure relief in the engine compartment near the firewall. Is this a fuel injected thing? Any other issues associated with the 460 to keep an eye out for?
Also, what's the better tranny to tow with the 460? Auto or manual? Which tranny is more reliable? Thanks.
Old Jun 11, 2002 | 06:23 AM
DeenHylton's Avatar
DeenHylton
89' 460?
For an 89 F250 460 stick with the C-6. Your towing capacity will be higher and the C-6's are virtually bullet-proof.
As far as the "buzzing" sound...I have an 89 F250 and have never heard the buzz...Deen
Old Jun 11, 2002 | 08:23 AM
rics91's Avatar
rics91
89' 460?
my truck has had the buzzing sound at shut off since day 1. don't know what it is, but i guess it's normal.
ric
91 f250s/c w/7.5L,banks power pak
Old Jun 12, 2002 | 03:10 AM
the law's Avatar
the law
89' 460?
Same here. It buzzes, but it doesn't seem to hurt anything, so I don't really let it bother me.
The Law
1989 F-250 HD 4x4
460, C6, BW 13-56
Almost Stock
Old Jun 15, 2002 | 07:57 PM
wingit1x's Avatar
wingit1x
89' 460?
My '90 F250 w/460 buzzes, and I've noticed a noise after the key is turned off in my friend's 2000 GMC 2500; not quite a buzz, but similar. When I first heard the noise, I suspected a pump or some such apperatus for the fuel return.... Is that likely?
Old Jun 28, 2002 | 11:41 PM
mike460's Avatar
mike460
89' 460?
i believe what it is is a fan that cools off the injectors. thats what i suspected when i went lookin at my efi I6, could be somethin else though, just throwing out somethin to look for
mike
Old Jul 2, 2002 | 05:16 PM
bb79ranch's Avatar
bb79ranch
89' 460?
Do you have the same noise when you push in the clutch before and while you shut engine off? As the engine is running in neutral and clutch pedal released do you hear a rumble or squealing sound coming from clutch-bellhousing area? If so you could have a number of things to causing the buzzing sound. (A) Throwout bearing. (B) Pilot bearing. (C) Transmission input shaft bearings, are just a few possibilities. My '90 F350 w/460 & 5 speed also has this sort of problem, sounds like a diesel when you shut off engine with clutch released. I will replace clutch,pressure plate, throwout & pilot bearing when time permits. I hope this helps in any way.
Todd
BB79RANCH
Old Jul 2, 2002 | 07:06 PM
redranger1's Avatar
redranger1
89' 460?
cobraguy
Oct 15, 2007 04:03 PM
RW1456
Oct 13, 2005 11:02 PM
79Ford460
Exhaust Systems
Jun 13, 2004 03:17 PM
pinultimate
Feb 20, 2003 08:38 PM
mgessner
Exhaust Systems
Sep 13, 2002 01:42 PM
