PCV, smog stuff
Old Jun 26, 2002 | 07:36 AM
georgedavila's Avatar
georgedavila
PCV, smog stuff
Old Jul 3, 2002 | 04:15 PM
dpoelstra's Avatar
dpoelstra
PCV, smog stuff
I replaced the stock aircleaner assembly with an open air leaner. I had to replace the oil filler with a vented unit, and I still need to connect the airpump to the aircleaner.
Question: Is what I am doing helping or hurting. Will the PCV system still function? I can replace the stock stuff for smog testing, but I just don't want to mess things up.
Thanks for your advice.
Old Jul 3, 2002 | 04:16 PM
dpoelstra's Avatar
dpoelstra
PCV, smog stuff
Oh...86 F350 460, C6.
Thanks
Old Jul 4, 2002 | 09:13 PM
phantom429's Avatar
phantom429
PCV, smog stuff
well Dan it is really hard to answer your question with out lookin at your truck. I can't remember if it is EFI or carbed. I will give you a general answer.
1. The air pump(s) intake air. If they take it from the ir cleaner you will have to either route the hoses to the air cleaner or create an air cleaner for the air pump as this air must be filtered.
2. The pcv system must have two things to operate properly. First of all on one end the breather. The breather takes filtered air (usually from the air cleaner) and is routed to one valve cover. The other half of the system uses manifold vacuum routed through a vacuum hose to a pcv valve. This p.c.v. valve is fitted into a rubber grommet in the valve cover opposite of the breather. When this system is in place it will draw any crank case fumes into the intake manifold to be burned. It also reduces chances of oil leaks by reducing the pressures in the crankcase acting on seals and gaskets.
3. An open element air cleaner DOES NOT create more power than a stock style air cleaner that draws cool outside air. This is if the stock style air cleaner does not pose a restriction to flow.
Hope this helps Good luck!!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
