D1VE block?
Old Jun 19, 2002 | 12:11 AM
trinogt's Avatar
trinogt
D1VE block?
While pulling my transmission, starter, and flywheel, I happened to look up and see the block casting. D1VE. Is this a special block, since it is 1971, or is it the same as a D5VE, D5TE, etc etc.???
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Jun 20, 2002 | 06:02 PM
tiethescore's Avatar
tiethescore
D1VE block?
Nothing special. Its a 1971 Lincoln block.
Old Jun 20, 2002 | 10:04 PM
gray79f250's Avatar
gray79f250
D1VE block?
same as mine
Old Jun 24, 2002 | 12:52 PM
Steve_Uzi's Avatar
Steve_Uzi
D1VE block?
same as mine too :P
Old Jun 24, 2002 | 05:36 PM
merc460's Avatar
merc460
D1VE block?
same as mine also Eric
Old Jun 25, 2002 | 09:19 AM
Fordzzzz77's Avatar
Fordzzzz77
D1VE block?
Mine is one year earlyer. DOVE-A
Old Jun 25, 2002 | 10:39 AM
georgedavila's Avatar
georgedavila
D1VE block?
The only real difference in non-Boss 385 series blocks '68-78 were the '70 DOOE CJ/SCJ 4-bolt and some 2-bolt DOVE blocks that have thicker castings around the main bearing webs. Deck height was changed but not enough to matter unless you're after serious hp. All the 2-bolt blocks are good for 650-700hp.
Old Jun 25, 2002 | 11:47 PM
trinogt's Avatar
trinogt
D1VE block?
I heard you can buy aluminum and iron blocks now with taller deck heights form some serious cubes... Does anyone know if this is a Motorsport block or other?
Mark
Old Jun 26, 2002 | 07:36 AM
georgedavila
D1VE block?
Ford Racing has always sold 4-bolt iron and aluminum blocks with a variety of deck heights. Their catalog is at most Ford dealer parts departments.
http://www.oemfordparts.com/
Old Jul 2, 2002 | 02:43 PM
Fordzzzz77's Avatar
Fordzzzz77
D1VE block?
>good for 650-700hp.
Hi georgedavila....Are you saying there is a D0OE block casting for the 385 series engines? I never seen one. I have seen CJ and SCJ blocks with DOVE-A as the casting in both the 2 bolt and 4 bolt version and ofcourse that nice thick main webbing. As far as I can tell between the standard DOVE-A (that you would find In a Lincoln)and the CJ DOVE-A is CJ stamp in the lifter gallary area oh about mid way up the block
Old Jul 2, 2002 | 03:24 PM
georgedavila
D1VE block?
My error. They were DOVE.
Old Jul 2, 2002 | 09:34 PM
Fordzzzz77's Avatar
Fordzzzz77
D1VE block?
Ding-Dang George........You had me thinking there for a moment. Could there be another casting???? That's one of the good things about this forum, you always can learn about Ford's old iron. Maybe this weekend I will take some pics of the DOVE and C9VE block main web and pan rail area and post it to this thread so the guy's of new and old call see what we are talking about.
Old Jul 2, 2002 | 10:09 PM
trinogt's Avatar
trinogt
D1VE block?
Just to throw another at ya... I just found a complete C6VE engine with intake and manifolds. I think it might be a 429. Everything was cast C6VE. Anyone have the code book?
Is this worth grabbing?
Mark
Old Jul 3, 2002 | 08:42 AM
georgedavila
D1VE block?
C8 is the earliest 429/460 I've ever seen or heard of.
Old Jul 3, 2002 | 09:14 AM
Fordzzzz77's Avatar
Fordzzzz77
D1VE block?
Maybe it's that 462 MEL.
