Pre Smog timing
Old Jan 14, 2008 | 03:52 AM
dirtyoffroad's Avatar
dirtyoffroad
Pre Smog timing
when you run the early "pre smog" timing set on a 79 460,what do you set your timing at,and what RPM?
Old Jan 14, 2008 | 03:58 AM
ford390gashog's Avatar
ford390gashog
With the straight up 0 degree set I would run it between 8 and 10 degrees intial advance. Use a vacuum gauge and timing light to get it perfect.
Old Jan 14, 2008 | 04:12 AM
dirtyoffroad
I started it yesterday,ballparked the idle,set it at 10BTDC,the fuel is probably a year old though.
dulcevendetta
Large Truck
May 3, 2016 10:49 PM
j66b
Mar 14, 2015 11:39 AM
BadDogKuzz
Mar 8, 2015 11:24 AM
Hardball
Jul 18, 2004 10:43 AM
blueoval79
13
Jul 16, 2002 12:19 AM
