which has solid front axles?
Old Jan 14, 2008 | 11:07 AM
superduty4x4's Avatar
superduty4x4
Originally Posted by Skandocious
Just trying to point out that there are always a few oddball people out there that want oddball things.
LMAO! That's probably an understatement!
Old Jan 14, 2008 | 11:27 AM
95F350XL's Avatar
95F350XL
All 4wd F250s and F350s are going to have leafs instead of coils. In order to get lift in the front you can either add-a-leaf, add blocks, or swap for lift springs.
I wouldnt be putting lift blocks in the front of a truck. Too much stress with turning. For the front add a leafs or new springs.
Old Jan 14, 2008 | 07:05 PM
reddogracing's Avatar
reddogracing
Thank for the inpit. I am thinking a 250 wouldnt be so bad to start with. Easier to find in the config I want. And since they have leafs, a front solid swap should not be problem.
Thats what I dont like about my 150, with coils, swapping over would not be practical.
Old Jan 14, 2008 | 08:48 PM
Skandocious's Avatar
Skandocious
Keep in mind that the swap will not be cheap. Parts alone will cost your upwards of $1000-1500. So whatever you buy, tack that amount on top
Old Jan 14, 2008 | 09:31 PM
reddogracing
lucky for me my friend has a junk yard, and likes to buy ford trucks, so parts should be there, unless you cant do a straight swap.
Old Jan 15, 2008 | 04:00 AM
Grey89F250's Avatar
Grey89F250
Where are you located, I need a friend who has a friend with a junk yard! LOL
Old Jan 15, 2008 | 09:19 AM
superduty4x4
I just got quoted $2200 for everything required to do the solid axle swap- front axle hub to hub, springs, steering linkage, track bar with bracket, front driveshaft, front yoke off T-case. Just FYI.
Old Jan 15, 2008 | 07:23 PM
82F100SWB's Avatar
82F100SWB
I'd like to see the door tag and axle weight rating off of that 97, I'd bet it started life with a D60 under the nose.
There are crew cabs with TTB out there, 96-97 they built F250 crew cab short beds, and they have the D50 TTB.
Leaf Sprung TTB to 85.5-97 D60 is a bolt in swap, just recently did it on a buddy's 86 F250 with an axle from a donor 93, took us longer to replace the bushings in the F350 springs than it did to do the swap.
Old Feb 18, 2008 | 07:18 PM
zamboni32's Avatar
zamboni32
For you F-150 owners, I completed a solid axle swap on my 94' F-150 last summer for under $1500. Used a Dana 44 from a 79" Bronco and kept the cushy coil springs. It is a true 7" lift with 35"s. I will be posting soon.
Jason
Walwal44
Sep 13, 2014 10:18 AM
TwistedFate
34
Oct 5, 2013 12:34 AM
gonecrazyi
26
Jul 27, 2007 09:39 PM
weldboy
May 4, 2006 12:01 PM
4xfordman
Feb 9, 2002 11:24 PM
