Sponsored by: Real Truck
4X4 Wont work?
Old Jan 13, 2008 | 07:46 PM
Graham567's Avatar
Graham567
4X4 Wont work?
Ive had my truck for about a year now and have not gotten around to fixing the 4X4. It was not working when i got it and ive been stuck several times so i need to do somthing about it. I have the dash selector and when i turn it from 4X2 to 4X4 high nothing happens and when i put it in 4X4 Low also nothing happens. I can get out and manually lock in the hubs and the driveshaft will spin but the wheels wont. I plugged my buddys swich into my truck and that didnt do anything. Im stumped on this one. Any ideas?
Old Jan 13, 2008 | 10:16 PM
Cowboy Brett's Avatar
Cowboy Brett
Did you check the fuse for it? If that was fine, then I'd check out the connector and harness at the actuator down on the transfer case and make sure the terminals inside aren't corroded up. It could be something as simple as that.
Old Jan 13, 2008 | 11:34 PM
ajorgensen's Avatar
ajorgensen
I had what seams to be the same problem in my 05 F350 and it was a bad shift pump on the transfer case.
Old Jan 14, 2008 | 11:33 PM
Graham567's Avatar
Graham567
ajorgensen, it effected the electric shifter and the manual hubs? If thats true then it will help me alot
thanks
Old Jan 14, 2008 | 11:41 PM
ajorgensen's Avatar
ajorgensen
It affected the electric shifter, the 4x4 light wouldn't even come on, the manual hubs worked fine and would spin the drive shaft when engaged but since the shift pump was junk no power was being put to the wheels.
Old Jan 14, 2008 | 11:47 PM
G BOBKA's Avatar
G BOBKA
Did you check this junkie, airlines that go to the front hubs? There's your A/C go to defroster? If so, the hoses that go to your hubs are probably rotted and no good. That would be a good place to look.
Old Jan 15, 2008 | 06:09 PM
Graham567's Avatar
Graham567
ajorgensen that sounds exactly the same as my problem ill go get it checked out. thanks
Old Jan 15, 2008 | 06:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
If you have stock hubs you have automatic hubs. Ford didn't make a Super Duty with an electronic transfer case and manual hubs. The hubs should have AUTOMATIC and LOCK on them.
2 things need to happen when you turn your switch to 4H or 4L. First, the hubs need to lock. To test this, start the truck and put it in 4H (while in park). Go to either front wheel, reach around it and try to turn the axle behind the wheel. If you can turn this, your hubs did not lock automatically. If you cannot turn the axle, the hubs are locked. Now, turn the switch to 2H and try the test again. Did the hubs unlock? If either test failed, you need to fix it. You probably need new hubs, maybe a new vacuum control servo. A lot of guys ditch the automatic hubs and get aftermarket manual hubs.
OK, now the second thing that has to happen is an electric motor needs to shift your transfer case. If you didn't get a light this probably didn't happen. If the fuses are all good you need to replace the transfer case shift motor.
Old Jan 15, 2008 | 06:26 PM
Mercury45's Avatar
Mercury45
lets make it simple, if your light does not come on the dash then you will never get 4wd
If you have a light chances are its a hub problem, if you have no light chances are its a switch or transfer case problem.
kenny
Old Jan 15, 2008 | 07:27 PM
Graham567's Avatar
Graham567
I know about the shift motor that was my original idea. I've got no light, the fuses are all good, and when i turn the switch into 4H i can freely spin the front drive shaft.
Old Jan 15, 2008 | 07:31 PM
G BOBKA's Avatar
G BOBKA
I know it sounds like a hassle, but I would pop the cover and take a looksee at what's going on inside. Something just doesn't sound right there.
Old Jan 15, 2008 | 09:04 PM
Mercury45's Avatar
Mercury45
and your sure its not the switch? That makes me lean even more towards transfer case motor
kenny
Old Jan 15, 2008 | 09:29 PM
Graham567's Avatar
Graham567
The switch is fine, that was the first thing i checked. when i start the car the 4x4 light comes on briefly then goes off. i don't know if that matters tho.
Old Jan 15, 2008 | 09:31 PM
Mercury45's Avatar
Mercury45
when you first turn it on the cluster does a light check... that means the light is working, the transfer case is not - at least thats my trouble shooting guess... maybe get down there and check the connections to the 4wd motor / transfer case... unplug um and plug them backl in?
this is just stuff i would try - i dont know if its right or not
kenny
