fabtech 3.5 hanger kit
P.S. I finally figured out how to post pictures
http://www.martialartsacademy.org/levilift.htm
As of now I have about 50K miles with this lift.
It has worked out very well, allowing me to travel
many thousands of miles on rugged off-road trails
while hauling my family and gear in comfort and style.
I have towed my boat all over baja, I drive twisty
mountain roads and in snow etc. in a very spirited
fashion, and tow my 30' plane/trailer with no ill effects.
This lift, combined with my other mods (see blog) have
allowed me really feel good about this vehicle, and unlock
its potential.
The ride was much improved, in that without a lift the
suspension constantly bottoms against the bump-stops
without one.
A stock diesel Ex has less than one inch of
up travel from the factory, and is unusable off road, unless
you are content to simply creep along.
The lift also allowed my to run 315/75/16 tires, which are
needed in the deep sand I often encounter, while much
improving the ride.
Hope this helps.
Quietman
www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers, Auto
-zone aftermarket voltage gauge, LANDYOT Generation II Radius Rods,
Ford factory hood insulator, Mojave Pin-Striping
