Spark Plug Removal Tool
Old Jan 13, 2008 | 02:30 PM
BIG BOI's Avatar
BIG BOI
Question everyone?
Is there a tool out there for the average Joe, which I can use to facilitate the removal of the two (2) rear spark plugs on the passenger side of the engine block as you’re looking at it? I don’t really want to go spend money at the dealership, I am a do it yourself type, so if there’s a special tool I can use to reach them, please let me know, or it to the dealership I go.
thanks
Old Jan 13, 2008 | 03:02 PM
afreemanmd's Avatar
afreemanmd
Sorry, I can't help you with the tools, but I just thought I'd mention that if you replace the plugs yourself make doubly sure they are torqued correctly and check them after a little while again. The early V10's have a bad habit of spitting out plugs if they aren't torqued right, in which you'd have huge DIY job putting steel inserts into the heads lol.
Just my $.02
Old Jan 13, 2008 | 03:54 PM
BIG BOI's Avatar
BIG BOI
thanks for the advice
Old Jan 13, 2008 | 07:03 PM
wylecoyote's Avatar
wylecoyote
When I did mine, I used nothing but a regular spark plug socket. I dont know why you would need any special tools. Good luck....
Brian
Old Jan 13, 2008 | 07:18 PM
BIG BOI's Avatar
BIG BOI
maybe my spark plug socket was a little too big or i think the rubber piece that holds the plug was worn, because about a year ago when i changed the plugs, it was a nightmare when it came to those two plugs in the back
Old Jan 13, 2008 | 07:22 PM
Stewart_H's Avatar
Stewart_H
Due to the setup on my Gen 2 Lightning, I purchased a set of KD magnetic swivel mounted spark plug socket removal tools.
Now I don't have to worry about the swivel's coming apart, and since it's a magnetic pick up, I don't have to "feel" for the plug to seat properly in the rubber bushing of my old socket plug.
This has made changing and checking my plugs a lot easier, especially for the back cylinders.
I haven't seen the engine setup on a V10, but I bet if you added this swivel socket it would make your back plugs even easier.
Stewart
Old Jan 13, 2008 | 07:29 PM
BIG BOI's Avatar
BIG BOI
thats what i need!!! where did you purchase this handy little tool?
Old Jan 13, 2008 | 07:33 PM
Stewart_H's Avatar
Stewart_H
Online. I think Northern Tools.
Just do a Google search. It should turn up some stuff for ya.
Stewart
Old Jan 13, 2008 | 07:43 PM
BIG BOI's Avatar
BIG BOI
Thanks for the info. life as just gotten good
Old Jan 13, 2008 | 09:58 PM
PhotoJoe's Avatar
PhotoJoe
This is the first link I found with it.
Old Jan 13, 2008 | 10:34 PM
Stewart_H's Avatar
Stewart_H
Yeah, that's for the double swivel socket.
Here are some links for the KD three-piece kit.
Stewart
Old Jan 14, 2008 | 07:12 PM
RACERX7775's Avatar
RACERX7775
the plugs are on the top of the engine on the v10's not he typical next to the exhaust manifold area on the 5.4L.
rwdfan
2004 - 2008 F150
34
Feb 28, 2013 04:33 PM
mswpj
2004 - 2008 F150
Nov 28, 2008 07:37 AM
Matt983
2004 - 2008 F150
102
Jun 12, 2008 02:28 PM
rjaywhit
Nov 5, 2007 12:38 PM
Joe
Oct 27, 1999 08:24 PM
