Spark plug removal
Old Nov 5, 2007 | 09:18 AM
rjaywhit's Avatar
rjaywhit
Spark plug removal
What's the trick to getting the back left spark plug out on a 360 with the AC box in the way?
I finally got it out but it's a real tight space to work in.
Any body recommend a special tool or method to get in there?
Thanks.
Old Nov 5, 2007 | 10:30 AM
Mil1ion's Avatar
Mil1ion
Lean right over the fender and grab the wire in one hand and the protective cover with the other hand.
Give it a twist first
Old Nov 5, 2007 | 10:31 AM
beartracks's Avatar
beartracks
A spark plug socket that has a hex on it. Then you can use a box end wrench.
Old Nov 5, 2007 | 11:44 AM
75F350's Avatar
75F350
^^^^ that's how I get to the stubborn ones.
I have even ground down the end of a Spark plug socket (with hex) to shorten it. The socket no longer works with a ratchet, (because the end of the plug sits in there now) but the little bit that it is shorter makes it much easier to get on the plug, and a box end wrench fits with the perfect angle for removal.
Old Nov 5, 2007 | 12:38 PM
coores14's Avatar
coores14
flex head socket adapter and a long extension to clear the box
ymirr
Apr 6, 2017 07:42 PM
B Dobz
Mar 27, 2012 03:44 AM
nickdoni
Modular V10 (6.8l)
54
Jan 3, 2011 07:20 PM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
seth1
1983 - 2012 Ranger & B-Series
Feb 6, 2004 08:53 PM
