Offroad & 4x4
airing down
Old Jan 13, 2008 | 08:34 AM
ovenrat's Avatar
ovenrat
Question airing down
just switched to BFG T/A KO's on my 08' FX4, as you guys probably know I had to go up to 285 65 18's(load range "E") as they don't make a stock size yet??, I kept the OEM FX4 rims, I'm running around 55 psi all 'round for gas mileage, yeah, a bit rough, but it's a truck right? :-)
Anything to be concerned about airing down to 20 psi on the sand?, I surf fish alot and this size BFG tire is spec'd for a 8 - 10" rim, our OEM rims are 7.5".
thanks
Old Jan 13, 2008 | 11:17 AM
75F350's Avatar
75F350
20 lbs will be no problem at all. When I was running stock rubber on the SD (brand new, no lift yet) and went to Glamis, I would air down to 12 to 15 lbs with no troubles at all.
Matter of fact, even with larger tires now, I often see pressure around 10 psi when I run around in the sand. I never get so aggressive that I am concerned about busting a bead, nor has it happened (yet) , and the advantages of a tire with reduced air pressures in the sand are night and day.
Old Jan 13, 2008 | 04:28 PM
Help I M Stuck's Avatar
Help I M Stuck
I do very agressive rock crawling with my BFG A/T's and run them at 12psi and have been doing it for 4 yrs now and have never had a problem.
Old Jan 14, 2008 | 10:03 AM
fishmanndotcom's Avatar
fishmanndotcom
you will be fine even at 15psi! dont be concerned unless you dip below about 12psi or you start making hard turns
-cutts-
Old Jan 14, 2008 | 02:14 PM
ovenrat's Avatar
ovenrat
Thumbs up Ok
thanks for the feedback.....
Old Jan 14, 2008 | 11:46 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Don't go lower than 12psi. It's a nightmare, not that its been done. Bad morning. Very bad
026TB4U
2009 - 2014 F150
15
Dec 9, 2013 09:52 AM
1979Mustang
Mar 4, 2011 08:32 AM
ovenrat
May 14, 2008 08:36 PM
YOMAN
2004 - 2008 F150
Aug 25, 2004 07:55 PM
Keith Smith
Mar 2, 2004 04:57 AM
