Need Help Please!
Old Jan 12, 2008 | 07:56 PM
bigjohn65's Avatar
bigjohn65
Need Help Please!
Hey guys. Greetings and salutations. Got a question about a 1960 ford F100 with a 292. Im installing this engine for a customer on a side job. And to be quite frank about it this thing has been a headache from day one. Ive succesfully reinstalled the engine and it starts and runs. Though the complaint now is that that it has no power. So I go to readjust the valves. I found specs to set them at .019. I did this. While the engine was running I noticed that the valves on the left bank are opening and closing just fine. BUT the valves on the right bank move hardly at all. Theres no lift. I tried to adjust but when I did this RPMS dropped and the engine sounded like it was trying to die. Is this screwed up machining on the cam? Or is it me? Can someone help me please?
Old Jan 12, 2008 | 08:27 PM
mtflat's Avatar
mtflat
Something isn't right. Cam lobes, pushrod length, valve stem length, etc...
I don't have a Y block - the experts will be along shortly. Welcome to FTE!
Old Jan 12, 2008 | 09:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Sounds like a bad cam. Why one bank would be bad is a puzzle. Maybe someone adjusted the valves incorrectly, wore out the lobes?
Old Jan 12, 2008 | 09:51 PM
bigjohn65's Avatar
bigjohn65
response
the engine was just rebuilt 3 weeks ago. they were supposed to put in a new cam. Thinking they may have remachined the old cam for a lack of a new one. I think maybe they got their math screwed up and milled it all wrong.
Old Jan 12, 2008 | 09:56 PM
havi's Avatar
havi
I'll have the Roast Duck
Or didn't have the Z additive when breaking it in
Old Jan 12, 2008 | 09:59 PM
bigjohn65's Avatar
bigjohn65
Z additive? Learn me please.
CIAF's Avatar
CIAF
Actually, that does happen when 2 guys work on an engine. I guy went to far and wore the cams down for that side. Or the eng did not get oil to that side and locked up the rods and they all bent?? All the y blocks that I have owned were great but I did learn of these probs from others with same issue.
I have even heard of guys using the wrong gasket on one side after repairing that side only. Using too short/long a push rod when replacing that head only. Just possibilities, still can't help answer your question. Have you gone on the Y Block forums??
Welcome to the FTE site, wish it were under better circumstances that you made your very first post. But, good luck, the pro's may be here shortly.
Jon
Old Jan 12, 2008 | 10:02 PM
CIAF's Avatar
CIAF
Woops, theres the rest of the story, I think you just got your answer.
Jon
Old Jan 12, 2008 | 10:07 PM
bigjohn65's Avatar
bigjohn65
Appreciate the welcome. Thank you. I pulled a couple of pushrods to compare length. They matched up and were still straight. ive been beating my head against the wall trying to figure this thing out. Just thankfull you guys are willing to lend me your wisdom and share your experience.
Old Jan 12, 2008 | 10:10 PM
havi's Avatar
havi
Jon, I think that makes the most sense, to me, too.
Modern oil companies are doing away with Z-additives, so if breaking in a new engine with modern oils, the "anti-wear" additive is lacking. This can ruin a cam in a very short time. Guys on the 335 forum have more info regarding the Z. Z=zinc oil additive. for flat tappet cams, it's pretty much a necessity.
Old Jan 12, 2008 | 10:15 PM
51dueller's Avatar
51dueller
Might be an interesting process to change a cam on a y-block since the lifters can only come out the bottom.
Old Jan 12, 2008 | 10:18 PM
bigjohn65's Avatar
bigjohn65
I just loosened up the rocker arm moved it over and pulled the pushrod from the top
Old Jan 12, 2008 | 10:22 PM
bigjohn65's Avatar
bigjohn65
How difficult is it to find a stock cam for this engine. Untill 3 weeks ago this thing was still all original and still running. A true testament to classic Ford engineering.
Old Jan 12, 2008 | 10:29 PM
bigwin56f100's Avatar
bigwin56f100
I dont think you have cam lobe problems ONLY on one bank. I THINK that maybe the decking of the block, milling of the heads may have been done wrong, and just maybe one bank has the 1.43 ratio rockers and the other side has the 1.54 ratio rockers.
Also, the cylinder heads may be different. Some came with small intake valves and some came with larger intake valves.
Some heads came with 80 cc chambers and some came with 69 cc chambers.
Were all the rods the same? some are longer than others. If this is the case, one bank maybe be at zero deck and the others might be .100" in the hole.
Hope this helps,
Kevin Bigwin
Doesnt sound good to me, did you do the rebuild?
Old Jan 12, 2008 | 10:36 PM
bigjohn65's Avatar
bigjohn65
Thanks. No. We had to send the original engine out. My customer sent it out through CHECKER. They sent it to a builder here in the valley. Personally I wasnt to crazy about the idea having checker do it. So if they did screw it up im dealing with a third party mess.
