Opinions Needed
Old Jan 12, 2008 | 07:00 PM
Fire85's Avatar
Fire85
Opinions Needed
I am going to buy a DP-tuner but I am looking for some input on what levels I should get. I don't do a whole lot of towing. It's a 2001 f-250 w/ 80K miles. I have installed a 4" lift with 35" tires, cold air intake, muffler delete and and the sonnax shift improver. Also I'm going to be installing guages and wanted to know where the best place to get these. I'd liek to get all 3 in a package if possible. My last question is what is the transgo tugger? Thanks ahead of time for the input.
Ben
Old Jan 12, 2008 | 07:19 PM
jhand124's Avatar
jhand124
Ben
I would go with 60t or 80t(if you tow light), 80e,120r, you could also add no start and high idle, if you idle alot in the summer (helps with AC). Your best bet is to give Jody a call and work it out with him, he will set you up.
I would check out Diesel Manor for gauges .
Transgo is a shift kit you have to pull the trans to install all of it, I think. I don't know much about it, but I'm sure someone here does.
Good luck
Old Jan 12, 2008 | 07:29 PM
ron's power stroke's Avatar
ron's power stroke
i like the tow shift's..i would get the 60tow ask jody for the 80 Econo with the tow shift... and the 80 is so good i never use my 120..some skip it and get the 140,,
Old Jan 14, 2008 | 02:09 PM
Fire85's Avatar
Fire85
I'm assuming that the tow shift is somthing you have to ask for specifically? Also what is the lope idle for and is there a big difference between the 120race 140 extreme and the 140 aggressive? I don't mean to drag this out but just wanted to hear what everyone has to say about each level.
Thanks,
Ben
646glsr
Nov 29, 2007 10:23 AM
BroncoKid
Bronco II
Oct 11, 2007 08:48 PM
shelljeep
Dec 28, 2006 08:58 AM
DeckedoutF150
13
Jan 31, 2005 01:07 PM
deadfish88
Dec 24, 2004 01:19 AM
