OIL Leak
Old Jan 11, 2008 | 02:56 PM
brianmp01's Avatar
brianmp01
OIL Leak
I have a oil leak i have two puddles in the valley behind the filter bowl i tried checking the lines but i don't know if i am retarded but i can't see were lines hook up does any one have pics the the lines that usually leak on the oil pump
Old Jan 11, 2008 | 04:06 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
You're not retarded. It's not easy to see back there. Are you sure you have leaking HPOP lines? Could the oil be coming from leaking CAC boots? Those are the orange boots under the turbo spider. If you haven't done the CCV mod then your boots could be leaking oil and it will puddle in the valley, right behind the fuel bowl.
Old Jan 14, 2008 | 02:02 PM
brianmp01's Avatar
brianmp01
no i have not done that mod what is it?
Old Jan 14, 2008 | 02:15 PM
Craig64's Avatar
Craig64
You might also run your fingers along the underside of the fuel bowl drain valve (yellow valve). If they come out wet, you might have a fuel leak instead of an oil leak
They're hard to tell apart sometimes.
Craig
