torque to yield head bolts?
Old Jan 12, 2008 | 05:06 PM
broncoman604's Avatar
broncoman604
A buddy has a 1994 F-250 with a 460 and they are replacing the drivers side head due to the fact somehow the front exhaust bolt hole broke. Anyway will this engine have TTY head bolts and how do you tell a TTY bolt from a normal one?
Old Jan 13, 2008 | 12:03 PM
Tiremine's Avatar
Tiremine
Found this article, hope it helps.
http://www.mondello.com/Pages/Articles/1/1.htm
Old Jan 13, 2008 | 07:46 PM
mark a.'s Avatar
mark a.
Why not drill it out ?
Old Jan 13, 2008 | 10:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The HOLE broke?!
Or it broke off IN the hole?
No room I'd imagine.
Helicoil, Keensert or weld up and retap?
Once you get those headbolts out You'll know why It'll take a BIG wrench to get them to yield. 140 ft lbs. ain't going to do it.
Old Jan 15, 2008 | 10:15 AM
wtroger's Avatar
wtroger
I was not aware that the 460 ever used TTY bolts. All I ever saw was grade 8 (i believe 9/16) standard thread bolts I always clean them completely run a tap down the threaded holes to clean blow them out then put a little light oil on the threads and torque them to spec in three steps.
Old Jan 15, 2008 | 10:12 PM
fasthauler's Avatar
fasthauler
I have pulled a lot of 460 heads and I have to agree with you. The only thing I do different is using Copper Anti-seize on the bolts. I have had trouble with putting oil on the threads. Sometimes the oil gets hot and carbonizes causing the bolts to seize. Also, I use a bottoming tap to make sure the hole get cleaned out all the way to the bottom. I had a heck of a time finding one and finally special ordered it from a specialty house. It cost quite a bit for those days.
Old Jan 17, 2008 | 11:07 AM
broncoman604
Sorry to just get back with you, they broke off the front hole boss for the manifold bolt and their easy solution was to replace the head.
Old Jan 18, 2008 | 07:39 AM
wtroger's Avatar
wtroger
Did they break it completely out? I have had to put a stud bolt in that one before.
Old Jan 18, 2008 | 10:04 PM
broncoman604
Yes they broke off the whole boss from the head.
imabass
Modular V10 (6.8l)
Jul 16, 2017 06:21 PM
163junk
Aug 7, 2016 12:19 AM
graphicjunkie
Jan 21, 2016 07:11 PM
hotrodfeguy
Aug 7, 2015 07:12 PM
JACKA$$
Jan 29, 2010 09:19 AM
