Exploder Transmission?
Old Jan 12, 2008 | 08:47 AM
woodly1069's Avatar
woodly1069
Does anyone know what the auto tranny would be in a 2003 4.0L Exploder? This thing seems to shudder at first when you put it into gear, then it seems fine. Could the converter be loose? If so, then how do I check it? Do I have to pull the starter because Ford is too stupid to put in an inspection cover?
Old Jan 12, 2008 | 09:19 AM
jdraughn's Avatar
jdraughn
Your not going to get much help by insulting most of the people who frequent these forums with name calling.
Old Jan 12, 2008 | 10:08 AM
mrshorty's Avatar
mrshorty
Isn't it a 5R55E?
Old Jan 12, 2008 | 10:12 AM
woodly1069's Avatar
woodly1069
I'm not really sure how to tell what it is. Is there a tag or something?
Old Jan 13, 2008 | 08:09 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/6...ight=oil+level
Old Jan 13, 2008 | 08:11 PM
steve(ill)'s Avatar
steve(ill)
a 2002 should be a 5 speed automatic, 5R55E. look at the above post to see how the check the fluid level from the drain pplug.-- this is a solenoid controlled, electronic transmission. it is very important to change the oil every 30k miles and put in a new filter. crud in the oil will plug the valves and "stick" the shift spools. changing the oil would be a good idea first.
Old Jan 13, 2008 | 09:24 PM
caseys's Avatar
caseys
Referencing Steve "the posting guru" link....since my post in that thread after having my tranny serviced I drove it over the hump to Pullman a distance of 300 miles. The tranny shifted and operated perfectly. Before that I had problems with shuddering as if running over a cattle guard. I also had the plug wires replaced due to a bad wire. I heard that this can cause shuddering too. After the plug wires changed out and the tranny serviced I am pleased and comfortable now after leaving the Explorer with my kid at college.
Casey
555 Studio
15
Mar 5, 2016 02:33 PM
brentleedragon
Washington Chapter
Feb 24, 2008 11:35 PM
92exploder
1978 - 1996 Big Bronco
Nov 15, 2003 02:49 PM
mchild
Jul 1, 2003 09:27 AM
andym
Aug 20, 2002 12:31 PM
