Trans Flush
Old Jan 17, 2008 | 12:19 PM
UP_There's Avatar
UP_There
Originally Posted by PRexcursion
Hi I have one question I have Just purchase a Excursion 2002 7.3 diesel and I wold like to know from some one with experience in this engine, what should I do do avoid expensive repairs... for example:
Should I remove the injectors to have them check and install new orings,,,,
I have replace the oil, diesel filter, transmision fluid whith its filter and basicali I want this truck to last me a long time and I dont want to be cheep.....
Thanks for your help, or maybe you have some one you now that can answer these question.....
PRexcursion......take a look at this site http://www.7point3.com/Mods.aspx
There are tons of things on there that can help your truck out. Also....you might post a new thread with your question, you'll get alot more responses to it, rather then in another one. Welcome to FTE
Old Jan 17, 2008 | 12:26 PM
PaysonPSD's Avatar
PaysonPSD
This is the link to Mark Kovalsky's ATF Change write up. Will answer many questions. Remeber, he is a former Ford Tranny Engineer.
https://www.ford-trucks.com/article/...nsmission.html
Old Jan 17, 2008 | 02:56 PM
Calli's Avatar
Calli
Things you need to get started:
The E4OD and 4R100 transmission system holds almost 18 quarts of ATF, and you must waste a couple of quarts to be sure you get it all purged and replaced, so buy 20 quarts of MERCON ATF [do NOT buy MERCON V!]. Ford also warns against using a fluid that has a dual MERCON and MERCON V rating. ? You may use either conventional or synthetic,
This should help. Carroll
Old Jan 17, 2008 | 05:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's a bit out of date. MERCON has been discontinued, and MERCON V has been changed to be compatible with the E4OD and 4R100.
Old Jan 17, 2008 | 08:11 PM
PaysonPSD's Avatar
PaysonPSD
Mark,
Thanks for the update on the use of MERCON V.
