Odometer light
Old Jan 11, 2008 | 04:25 PM
Gage2502's Avatar
Gage2502
Odometer light
On my 2000 Expedition XLT the odometer light fades while driving and then it comes back on. Any ideas?
Thanks ~Gage~
Old Jan 11, 2008 | 05:26 PM
anfo's Avatar
anfo
Bad coil pack.
anfo's Avatar
anfo
Vacuum leak at the elbow behind the manifold.
Old Jan 11, 2008 | 05:28 PM
anfo's Avatar
anfo
Add 4oz. of friction modifier.
Old Jan 11, 2008 | 05:48 PM
madsonp's Avatar
madsonp
Try this https://www.ford-trucks.com/forums/1...25252Bblackout
Old Jan 11, 2008 | 06:13 PM
Gage2502's Avatar
Gage2502
Thanks for the info, madsonp Im going to try that when I get a chance.
~Gage~
Old Jan 11, 2008 | 06:35 PM
madsonp's Avatar
madsonp
I had the same problem with mine and following the info on that link I was able to fix it. The dash is kind of a trick to get off though if you haven't done it before but it's not to bad. If you have an auto repair manual it'll show you how to remove the head light switch and other things you'll need to know.
Old Jan 11, 2008 | 11:16 PM
madsonp's Avatar
madsonp
Here's a link I found showing how to remove the dash if you need it.
http://www.scribd.com/doc/377317/Expedition
Old Feb 28, 2008 | 01:05 PM
lees40's Avatar
lees40
Hi there. I have a 2000 Expedition with this problem, as well as the overhead display with the outside temp. started working erratically, then finally stopped working completely. Anyone know how to fix that?
Old Feb 28, 2008 | 05:25 PM
madsonp's Avatar
madsonp
I think what you might do is pull your OVHD console, and try unplugging the harness, use a little electrical contact cleaner on the contacts then plug it back in and see if that does anything. If that doesn't work, pull the display and check for cold solder joints on the circut board (similar to the problem on the odomiter display) and solder up any you find. If that doesn't work, I don't know what to tell you.
Old Feb 28, 2008 | 07:52 PM
FTE Herman's Avatar
FTE Herman
Originally Posted by anfo
Bad coil pack.
Three common answers, but to the wrong question.
Old Feb 28, 2008 | 08:02 PM
lees40's Avatar
lees40
Thanks for the help, I received a lot of replies on this one, sounds like a lot of people have had this issue. I'm going to get out a soldering pencil and take a crack at it this weekend! I appreciate all the help.
junkkingranch
May 15, 2017 10:48 AM
Brain's 97 Diesel
30
Dec 19, 2015 06:49 PM
megabell28
Aug 19, 2012 12:45 PM
300rwhp
Mar 28, 2009 05:05 PM
daigles
Jul 31, 2003 07:07 PM
