Cutting Off
Old Jan 11, 2008 | 03:11 PM
TeamAL's Avatar
TeamAL
Cutting Off
I have an 87 F150 that has recently started to just cut off. If I drive it for more than about 15 miles it will just die. If I let it sit for about half an hour it will run again for another 15 miles. Any ideas why? I have been it might have something to do with the coil.
Thanks for any help.
Old Jan 11, 2008 | 03:31 PM
chrisf250-460's Avatar
chrisf250-460
welcome to FTE.without knowing what engine size or possible codes,i have been reading on here alot about the ignition module getting hot,then when it cools it will restart.
Old Jan 11, 2008 | 03:37 PM
Skandocious's Avatar
Skandocious
Yep, the ignition coils can sometimes do this when they're on their way out. They'll heat up and malfunction then cool off and run correctly again 'til they get hot. First thing is to get those codes pulled.
Welcome to the site brother
Old Jan 14, 2008 | 10:20 PM
Old_Paint's Avatar
Old_Paint
87 model would have the dizzy mounted TFI, wouldn't it? Those were most prone to the heating problem, simply because of location. Moving to massive heatsinks on the fender helped, but didn't eliminate the problem, apparently. Albeit, I'm still running on the original in my '92.
varmit22
Jul 6, 2014 08:20 AM
gatormccluskey
Aug 24, 2013 06:26 PM
TKnight10
16
Jan 29, 2013 04:35 PM
Rancid81
Jan 10, 2010 07:07 PM
pubman
Apr 8, 2007 02:05 AM
