"Tune up?"
Old Jan 11, 2008 | 12:09 PM
ghunt's Avatar
ghunt
"Tune up?"
Is there such a thing for these engines?
Old Jan 11, 2008 | 12:43 PM
tbone91's Avatar
tbone91
Change the oil. Clean the CDR valve. Change oil, air, and fuel filters.
The air filter is usually the one that makes the biggest difference in power and MPG.
Old Jan 11, 2008 | 03:40 PM
dyoungen's Avatar
dyoungen
I will second the CHANGE the air filter. Makes a BIG differance. I've seen the referance to a "CDR" valve. Where is it and what does it look like?
Old Jan 11, 2008 | 03:48 PM
David85's Avatar
David85
If its non turbo, the CDR is located under the rear of the air filter. You have to take the whole air cleaner assembly to get to it. It looks about the size of a tuna can.
Old Jan 11, 2008 | 07:22 PM
dyoungen's Avatar
dyoungen
THANK YOU!! I called a Diesel/turbo/electrical specialty shop after I posted the question earlier and asked the guy I know that works there what is a "CDR"? He had no idea, in fact he asked a coworker that just went to school on Diesels if he knew what I was talking about and he had no idea. Again THANK YOU!!
Old Jan 11, 2008 | 08:17 PM
David85's Avatar
David85
I think some ford documentation calls it a "crank case vent adapter".
Old Jan 12, 2008 | 10:47 AM
Dave Sponaugle's Avatar
Dave Sponaugle
This is a CDR.
My engine is a turbo'd, so the bottom would look a bit different on a NA motor.
Mtnhermit
Apr 30, 2016 12:57 AM
Schmitty
Jul 1, 2004 11:45 AM
