How much black smoke is normal
Old Jan 11, 2008 | 09:24 AM
preppypyro's Avatar
preppypyro
I was cruising around in my ol 89 ford yesterday and I starting looking at when guys in diesel truck were driving. I was checking out the black smoke coming from the tailpipes. Some trucks seemed to have alot more then others, and I was kind of comparing the approximate same years and driving styles. Can anyone fill me in on why one truck could smoke black alot more then another, when the driver didnt really appear to be putting his foot to the floor?
Old Jan 11, 2008 | 09:49 AM
Smokin''s Avatar
Smokin'
Smokin
There are lots of variables..the main one being chips / tuners / programmers. More fuel = more power = more black smoke.
Old Jan 11, 2008 | 09:56 AM
preppypyro's Avatar
preppypyro
Yeah I had that figured for sure. These appeared to be stock trucks. No exhaust or gauges, could have been chipped though for sure.
Old Jan 11, 2008 | 09:57 AM
bdrummonds's Avatar
bdrummonds
It also depends on if it is a newer computer controlled diesel, the older mechanical diesels smoke much more than our "green" trucks do.
Old Jan 11, 2008 | 10:08 AM
Smokin''s Avatar
Smokin'
Smokin
I've seen some earlier 12 valve Cummins blow black smoke between shifts just idling along at 40 MPH.
Old Jan 11, 2008 | 10:10 AM
ron's power stroke's Avatar
ron's power stroke
low boost and dirty air filters will make it blow black smoke/..after putting in my EBPS i noticed its a little harder to make it smoke
Old Jan 11, 2008 | 10:28 AM
Paul Moody's Avatar
Paul Moody
Engine condition has alot to do with it. I used to own a 87 6.9 diesel. It was a smoker. Come to find out it had bad compression in a couple of cylinders and was pretty worn out. When I put the pedal down it puffed pretty good and smoked steady at normal crusing speed. When I test drove my 2000 7.3 I made sure it wasn't a smoker. All stock it looked great and has been a good truck.
Old Jan 11, 2008 | 01:00 PM
haulingboat's Avatar
haulingboat
The boss has a brand new 6.4. When it goes into regen mode it will pour black smoke. Sometime so bad that people start backing off to avoid the rapture. Regen finishes and it cleans right up.
Old Jan 11, 2008 | 04:10 PM
JMac444's Avatar
JMac444
All depends on load and throttle postion. Even mine empty if i boot it in the *** it will throw some good coal out and im stock and she has 0 problems.
Old Jan 11, 2008 | 05:33 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Alot of the Duramax drivers like to be Sleepers. Most of them in the 600+ range look completely stock aside from maybe a 4" exhaust.
