Piston or Valve ?
Old Aug 24, 2002 | 09:14 AM
trackcat's Avatar
trackcat
Post Piston or Valve ?
MY 460 STARTED TO MAKE NOISE WHILE DRIVING 60 ON HWY. AT FIRST I THOUGHT IT MAY BE THE A/C COMPRESSOR KNOCKING. I HAVE NOT PULLED IT DOWN YET BUT I THINK THE LOWER END IS O K . IT HAS GOOD OIL PRESURE AND DOSE NOT MISFIRE. WHEN I REMOVE PLUG WIRE FROM # 7 THE KNOCK IS 50% LESS. THE MOTOR HAS 43000 MILES AND PULLS 34 FT MOTORHOME AND 2500 LB NEON TOAD. ANY ADVISE I CAN GET WOULD HELP BEFOR I TEAR IT DOWN WOULD HELP TRACKCAT
Old Aug 24, 2002 | 10:49 AM
vkaro45's Avatar
vkaro45
Piston or Valve ?
Hi,
On my 460, the knocking sound turned out to be a wrist pin. Try running a wet and dry compression test to determine if you have a bent or burnt valve. Good luck.
Rodger.
p.s. Could you please turn off the caps lock. It's the internet equivelant of shouting. Thanks
Old Aug 24, 2002 | 08:06 PM
LxMan1's Avatar
LxMan1
Piston or Valve ?
You Can spin a rod bearing and still have good oil pressure!!
Old Aug 25, 2002 | 09:20 AM
georgedavila's Avatar
georgedavila
Piston or Valve ?
I'd say tear it down before you incur possible additional damage. As the others mentioned, your oil pressure won't be affected by a bad wrist pin or spun bearing.
Old Aug 25, 2002 | 05:34 PM
phantom429's Avatar
phantom429
Piston or Valve ?
klashorst
Dec 27, 2011 07:01 PM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
Celicadude
Sep 25, 2006 11:50 AM
J&B
20
Jul 6, 2004 05:44 PM
therigwelder
Jul 18, 2001 10:13 PM
