6" Stack Install
Old Jan 12, 2008 | 09:53 AM
Epd444's Avatar
Epd444
My friend had a 94 (non powerstroke) diesel. He put just that stacks up through the bed but then again it was NOT a powerstroke.
Old Jan 12, 2008 | 10:20 AM
Diesel nut's Avatar
Diesel nut
Why dont you do what I did here?
Old Jan 12, 2008 | 10:28 AM
Diesel nut's Avatar
Diesel nut
This is a 2x6 inch box pipe wth the ends welded shut. It didnt cost me much of anything to make. the stacks, clamps and s.s flex pipe were about $300
Old Jan 12, 2008 | 10:36 AM
strokin'_tatsch's Avatar
strokin'_tatsch
is that 2x6 box pipe not a major restriction??? it looks very restrictive
Old Jan 12, 2008 | 10:41 AM
Diesel nut's Avatar
Diesel nut
It runs the same as it did before I put it on. I did notice it muffles the sound a little bit. If you dont like the 2x6 then use a 4x6 pipe. I just used this because its what I had laying in the scrap pile. I put this on in July of '03.
Old Jan 12, 2008 | 10:53 AM
strokin'_tatsch
i must say, i'm surprised that your EGT's don't get out of control, but if it's cheap and it works then use it right? i'm like that on a lot of things as well.
Old Jan 12, 2008 | 11:31 AM
Diesel nut's Avatar
Diesel nut
The highest Ive seen my egt's go is 950.
Old Jan 12, 2008 | 02:21 PM
tjbeggs's Avatar
tjbeggs
The stacks that were in my truck when I bought it had a similiar set up with 3x3 tubing in the bed with a hacked up 3.5 inch stock exhaust under the truck. When I removed that system and built my side pipe with 5" from the DP out I dropped 50°. There are a few different variables to the set up but mine with a tubing like that wasn't the best flowing deal. I think the biggest thing was it had a 3 inch inlet and 3 inch or so outlets to each stack.
I can't wait to redo my stacks and get them back on!! Took my topper off Thursday so hopefully stack in a month or so.
Old Jan 12, 2008 | 03:51 PM
custom_nirvana's Avatar
custom_nirvana
ALL DONE!!!!! Must say looks great and sounds even better, was able to lose my little muffler.
Old Jan 12, 2008 | 03:53 PM
custom_nirvana
Old Jan 12, 2008 | 04:03 PM
custom_nirvana
Also i have this Bully Dog tip if anyone is interrested.
[img=http://img99.imageshack.us/img99/8162/0112081631fv6.th.jpg]
Old Jan 12, 2008 | 04:39 PM
tjbeggs's Avatar
tjbeggs
looks good!! congrats!
Old Jan 12, 2008 | 04:52 PM
  #28
fordman837000's Avatar
fordman837000
just finished my stacks too but I only did 4" stacks and made them myself out of 3" emt 90* bends and painted the pipes exept for the tips with BBQ and stove high temp paint but forgot the one major thing! a flex pipe! man does it rattle oops might be the bolt that my son dropped in there oops any suggestions on getting it out? I have tried a magnet on a string but knew that wasn ' t going far in a metal pipe lol
Old Jan 12, 2008 | 09:03 PM
  #29
strokin'_tatsch
you will probably have to take the flex pipe off and get it out that way.
nirvana, the stacks look great!!!!!!
Old Jan 12, 2008 | 10:09 PM
  #30
custom_nirvana
Thanks to my niffty mp3 player i was able to record some sound bites.
Getting on it.
http://www.supload.com/sound_confirm...1312741314.wav
Idle
http://www.supload.com/sound_confirm...=847758992.wav
