Brake bleeding
Old Jan 10, 2008 | 08:17 PM
burner718's Avatar
burner718
Brake bleeding
Just replaced calipers on front of my '96 7.3. As far as bleeding, I read you should do Right Rear, Left Rear, ABS Valve, Right Front, Left Front. My question is, is the RABS valve the one on the rear axle, with the two left and right brake lines going to the rear cylinders? It has what appears to be a bigger bleeder on it.....and a vent hose.
Old Jan 10, 2008 | 08:34 PM
95F350XL's Avatar
95F350XL
You do not have to do the RABS valve. But if you only did front you only have to bleed the front. But bleed the ones furthest away from the master 1st. So yes RR, LR, RF, LF. You know the propper way to bleed? Have a buddy pump the pedal with the truck off, like 10 times or so, have him hold it while you open the bleeder, before the fluid stops close the bleeder. Do a few times to each side, and then run the truck and try it out.
Old Jan 11, 2008 | 08:19 AM
44dwarf's Avatar
44dwarf
That line on the rear axle with the hose on it is not a bleader it is the rear axle vent it just holds down the "T" fitting for the rear lines.
The RABS valve is under the drivers door follow the lines from the master cyl they go down to the valve.
44
Old Jan 11, 2008 | 10:52 AM
131will's Avatar
131will
I always heard you needed to bleed the brakes with the motor running as to not take a chance on busting the diaphram in the brake booster. I have done it both ways with no problems though.
Old Jan 11, 2008 | 11:25 AM
andym's Avatar
andym
Yes, you have to bleed the ABS valve, or you'll be back here asking why your brakes are so soft. No, you don't have to have the engine running.
Old Jan 11, 2008 | 01:07 PM
burner718's Avatar
burner718
Thanks ya'll....great info......now I'm off to bleed.
raven3
Jun 25, 2014 01:48 PM
dukefan70
Apr 18, 2012 07:33 PM
HENDEL JR
Sep 23, 2005 07:28 PM
tack338
21
Jul 17, 2003 08:37 PM
picman25
Jul 5, 2002 07:09 AM
