Engine Options
Old Jan 10, 2008 | 02:33 PM
Dajudge51's Avatar
Dajudge51
Wink Engine Options
Can anyone tell me the factory installed engine options for a 67 thru 72 F 100??
Thanks All,
Larry
Old Jan 10, 2008 | 04:05 PM
gnwalker's Avatar
gnwalker
'67-'68: 240 standard, 300, 352
'69: 240 standard, 300, 390
'70: 240 standard, 300, 360, 390
'71-'72: 240 standard, 300, 302, 330, 360, 361, 390
Old Jan 10, 2008 | 07:32 PM
limegoldf100's Avatar
limegoldf100
The 352 was dropped after 1967. The 360 and 390 were available from 68-76. The 302 was offered from mid-1969 to 1996. No F-100 was ever factory equipped with a 330 or 361.
Old Jan 10, 2008 | 09:02 PM
Customcab's Avatar
Customcab
So gnwalker is pretty much right; except 360 is/was a 68 option & the 330 361 aren't a factory installed option at all?
Mitch
Old Jan 10, 2008 | 10:37 PM
Dajudge51's Avatar
Dajudge51
Thanks for all the helpful info guys.
Larry
Old Jan 11, 2008 | 02:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/79 F100/350 engine sizes
The 240 1V is the standard engine for: 1967/74 F100/350's. 240's replaced by 300's in 1975.
Optional Engines
1967: 300 I-6 / 352 V8
1968/72: 300 I-6 / 302 2V (1969/72 F100 only) / 360 2V / 390 2V.
1973/76: 300 1V (1973/74 only) / 302 2V / 360 2V / 390 2V / 390 4V (1975/76 only) / 460 4V
1977/79: 302 2V / 351M 2V / 400 2V / 460 4V
Only the F500 and larger trucks used 330/361/391 FT engines thru 1978, with one exception.
Only the 1973/79 F350's with dual rear wheels sold to U-Haul came with FT 330's.
These are not pickups, but Cab & Chassis. Ford built these truck especially for U-Haul. U-Haul added their own box body.
Old Jan 11, 2008 | 10:00 AM
Dajudge51's Avatar
Dajudge51
Thanks a lot for all the info.
Larry K
Old Jan 11, 2008 | 10:03 AM
mikem55's Avatar
mikem55
330ft
bill, do you have the firing order for the 330,361, 391 fts.my truck is a 69n750 but it has 391 valve covers and a four barrel holley. the valve cover has 72 391 info so i dont know what kind of animal this is.thanks mike
pancotto
New Member Introductions
Mar 31, 2017 06:27 AM
metalcaster
Aug 31, 2016 10:40 AM
72_Mach1
Aug 25, 2016 04:44 PM
robbyriot
15
Apr 9, 2016 12:05 PM
Greenstreak
Mar 15, 2012 05:59 PM
