Electrical Hum??
Old Jan 10, 2008 | 10:57 AM
loufres's Avatar
loufres
Electrical Hum??
My 02' 7.3 has an electrical humm coming from under the hood near the fuel filtter......keep in mind the ignition switch is off. I opened the fuel drain and the humm went away.....sort of.It actually got quieter. I pulled the fuel pump fuse but the hum continues. Any ideas?
Old Jan 10, 2008 | 11:08 AM
whjco's Avatar
whjco
Maybe it's a vacuum leak.
It might also be the vacuum pump, but it shouldn't be running if your key is off.
Maybe pressurized fuel bleeding off?
BJ Lexington, KY
Old Jan 10, 2008 | 11:18 AM
loufres's Avatar
loufres
I also thought of pressurized fuel bleeding off but it's been going on non- stop for a couple of days. My next step is to disconnect the batteries to verify that it is electrical.
Old Jan 10, 2008 | 11:40 AM
1996pwrstrk's Avatar
1996pwrstrk
Did you check the two relays ( the GPR and AIH ) ? Does it do it all the time or just after it has been run ? If you go out in the morning after sitting all night is it doing it ?
Old Jan 10, 2008 | 11:46 AM
loufres's Avatar
loufres
I touched the relays for vibration.....they weren't. I first noticed the problem yester day morning and it was still humming this morning.
Old Jan 10, 2008 | 11:51 AM
1996pwrstrk
I would go ahead and disconnect the batteries and see if it still there.
mbaquet
2004 - 2008 F150
17
Nov 15, 2016 01:01 AM
jessie1234
Mar 10, 2014 10:06 AM
Stretch8z
Jan 6, 2010 09:31 AM
fellro86
29
Feb 22, 2009 09:30 PM
Bronco86
Dec 30, 2003 10:05 AM
