Schaeffer 9000, anyone interested?
https://www.ford-trucks.com/forums/6...ao-report.html
I already have 4 gallons each of Rotella T dino and Rotella synthetic in the garage. I was planning on switching to synthetic oil after I used up the Rotella T, but I think I want to make the switch with the next oil change. I have a Oilguard bypass filter coming and the ESP luber has been sitting here for a while now. I will be putting both systems in at the same time, and would rather just have everything filled with the same oil all at once.
Anyhow, I made some calls and in order to get free shipping I would need to place an order for $300 or more. I'm in Eastern Connecticut and work in Providence RI, so I thought I'd see if anyone in the CT/MA/RI area was interested in getting some Schaeffer oil. The pricing works out to $16.30 a gallon for the Supreme 9000. If you prefer the Supreme 7000 I could get prices for that too. Schaeffer also makes a fuel additive which comes 24 bottles to the case for $6 each and treats up to 125 gallons of fuel IIRC. If you're interested in going in together to get any of the Schaeffer stuff just let me know.
I'm thinking that between the shear resistance of the oil, the bypass filter, and the pre/post luber system I should be reducing most of the wear on my engine and may see a slight boost in mileage.
