E350 Bus with a 460
Old Sep 16, 2002 | 11:56 AM
Nonot's Avatar
Nonot
E350 Bus with a 460
I posted this as a reply to the excellent response to my original append and have not heard a word since.?
What do you think about the air scoop idea?
Is there a neat and easy way to get some cool air into this thing.
I also saw a post about flat top pistons.
I have a set of TRW 11.5:1 +.060 for a 460??
IF I machined off the domes. Make these Flat top pistons I perhaps could get to the 9.5:1 compression or so. I
would like to run cheap gas if possible.
I also need clarified several appends on camshaft timing.
We run the mudracer cam 2 degrees advanced from Straight up with a crower 311HDP cam.
If I understand all the posts about this ford has retarded the cam 4 degrees which lowers the cylinder pressure at
low RPM.
The question is using an aftermarket cam and a degree wheel I should be able to advance 2-4 degrees with no
issues BUT IF I retain the stock CAM straight up is the as far as I can go.
I will be back online Wednesday(2 days off Wahoo)
Originally posted last Sunday
Thanks
Have Fun
Tim
P.S.
I have a turbo available and have been toying with putiing it on this truck.3-5 LBS of boost and perhaps
water/methanol injection to control detonation?
How does the 1988 EFI react to being Turboed.
Great forum with some excellent info
Old Sep 16, 2002 | 12:22 PM
dpoelstra's Avatar
dpoelstra
E350 Bus with a 460
Stock Cams go Straight up. I thought I could advance my stock cam 4 degrees, and it won't work well. Mosty aftermarket cams have an advance built into them, so check the manufacturer, most will say to NOT advance them past straight up.
Old Sep 16, 2002 | 05:32 PM
Quantrex's Avatar
Quantrex
E350 Bus with a 460
FORDF250HDXLT
166
Jan 22, 2022 01:04 PM
jeremy5wilburn
Oct 12, 2016 04:23 PM
F-250 restorer
Oct 5, 2010 07:24 PM
F350 Strait
May 17, 2010 01:21 PM
81f2504x4
Apr 26, 2004 03:10 PM
