MKO exhaust install
Old Jan 9, 2008 | 12:52 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
MKO exhaust install
I know some of you guys have the MKO 4" exhaust. Does the downpipe fit in with out having to move the tranny cross member? How did the kit go together? Pretty easy install?
Old Jan 9, 2008 | 12:57 PM
ron's power stroke's Avatar
ron's power stroke
its not too bad...but its a lot better to have help with the down Pipe...the DP is a tight fit..so look close....after it is all hung lossely..start at the turbo and work back and tighten the clamps....the washers on the hangers may jingle..i put permatex on them and this stoped that...
Old Jan 9, 2008 | 01:29 PM
MikeSDK's Avatar
MikeSDK
When my brother and I did the down pipe on my truck, I held it steady from under the truck while he tightened the clamp from under the hood.
The rest is very easy.... the hardest time we had on mine was trying to figure out which section was the tailpipe! Those last two sections around the rear axle look pretty similar, and I'n my case I had to slightly bend a couple of the pipe ends so that they would slide onto each other.
Old Jan 9, 2008 | 01:51 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Yes, you should not need to move anything. Just as everyone else said, extra pair of hands helps.
Old Jan 9, 2008 | 05:33 PM
Stroker 94 1/2
Thnaks for the help fellas!!
Old Jan 9, 2008 | 06:07 PM
98SVTCobra's Avatar
98SVTCobra
I did not use any of the loose washers that came with my kit because they rattled and made a awful noise at times going down the road.
Old Jan 9, 2008 | 06:11 PM
ron's power stroke
one last thing...start spraying the V clamp on the down pipe with PB Blast from now till you do the job..the more the better..
Old Jan 10, 2008 | 02:01 PM
Stroker 94 1/2
What washers are you guys talking about?
Old Jan 10, 2008 | 02:06 PM
ron's power stroke
the hangers on the MKO goes into the rubber..then you slide on a washer. and poke a cotter pin though...the washers will jingle when the truck is at idle..i put some permotex (blue form-a-gasket) on the washers after it was installed to stop the jingle...it drove me nuts...
Old Jan 10, 2008 | 02:14 PM
monsterbaby's Avatar
monsterbaby
only had one that rattled on mine, happened to have the wire feed out and close to the truck one day, hooked the ground lead to the tail pipe and just a short spot weld on the washer to hanger and no more rattle (ok might make it a little pain to get off but only just a real small tack did the trick)
Old Jan 10, 2008 | 02:20 PM
ron's power stroke
nice to have a welder around when you need it.. i had 2 or 3 washers when i first started it up..all i had was the permotex..so i went and did all of them while i was at it..little over a year and still no jingle..i also painted my exhaust with black stove paint to make them last longer...so far so good..im going to need to do it again here soon though..but no rust yet...
Old Jan 10, 2008 | 02:33 PM
Stroker 94 1/2
Thanks guys!! Hopefully I will be ordering this next week and I'll take care of this when I install it.
Old Jan 10, 2008 | 05:10 PM
sideshow's Avatar
sideshow
i didn't have to do it on my truck, but on my brother in laws duramax, his rattled like holy hell. so we bought some rubber grommets, forced them into the washer opening, and bye bye rattle. easy on and off. on my truck, i had the muffler shop cut and weld the last bend so it exited at more of an angle towards the bumper. i had a little trouble with the pipe being closer to my shock than i wandte so the mechanic stacked several washers together, and made a quick bead across all of them. put about 5 washers together, and put them on the side of the hanger you want the pipe to move towards, and it will "pull" the pipe over. no rattle either.
foxracer800
31
Jun 24, 2009 08:41 PM
BDalton
30
May 28, 2009 07:46 PM
DieselBeast01
31
Jan 9, 2009 09:26 AM
crazymut
20
Jun 6, 2008 01:39 PM
ggmfl77
Mar 7, 2007 10:08 PM
