i have one ? about my egts.I had the banks egt and turbo gauge put on and they put the senser post turbo, someone was saying that if banks did not calibrate the guage for post turbo readings that i need to add about three hundred degrees to what the gauge is actully reading is this true?
The reason post-turbo EGT's are a no no is because there is no set rule of thumb to add "x" amount of degrees to your reading. Pre-turbo EGT redline is 1250 degrees. You can go over that in short spurts, such as drag racing or tractor pulling. If you sustain over 1250 degrees while pulling up a long grade for several miles, then you can start to melt the aluminum pistons. Again, this is Pre-turbo EGT's were talking about.
Post-turbo EGT's vary wildly in relation to the pre-turbo readings. As the hot exhaust gas hits the turbo, the turbo itself will absorb some of that heat. The amount of heat taken by the turbo depends on engine load, outside air temps, barometer, vehicle speed, etc. As you can see there is a big list of factors that all play a part.
Now if you were to hook up a pre and a post EGT gauge, you can watch how wildly the temperatures vary. In some cases you might only see a 50 degree difference, and at other times you might see up to a 500 degree difference. So by only adding 300 degrees, you aren't always safe. There is one user who visits here every now and again who blew his first engine because he went only with post-turbo EGT's and used that 300 degree mark difference to try and guess the actual temps. Right now he has a melted Powerstroke piston on his desk as a cupholder.
See, this place is just full of usefull info. I did alot of reading on here before I installed my gauges, pre turbo was stressed a great deal and the reasons make allot of sense to me.
I don't have one yet but everything I've read on here says it will help. It makes sence, not only bigger pipe but bigger down tube and all of it is mandrel bent.
Welcome to the site, you made a good choice coming here. Have a look at the first thread on the board, lots of good ideas, info, and other goodies there. Then have a look at the 7point3 link in my signature, some of the same info and some other. After your 25th post, take time to fill out you sig. so we will know you and your truck.
