front rotor problem
Old Jan 8, 2008 | 04:23 PM
toolbeltdiva's Avatar
toolbeltdiva
Red face front rotor problem
I have a 90 F150 2wheel. I use it for my business so it's driven alot. My front drivers side rotor is getting grooves in it all the time right away even right after I do a brake job, my caliper seems to be okay could that be doing the damage. Also just recently it started acting wierd. When you put it into gear you know it usually moves forward or whatever when you release the brake well it hasn't been doing that lately? I know some about brakes but not alot still learning. If anyone could offer advice I would deaply appreciate it.
Old Jan 8, 2008 | 04:29 PM
JRCF's Avatar
JRCF
I would say sticky caliper for sure, If you are wearing grooves in your rotors after doing a pad job then that would be your issue. Does it pull to one side when braking? that often is a sign as well.
Old Jan 8, 2008 | 04:33 PM
toolbeltdiva
yes it does pull a little, sticky caliper can it be fixed or just be replaced? Thanks
Old Jan 8, 2008 | 04:53 PM
JRCF's Avatar
JRCF
Replace both on the front is the ideal solution. Bleed the new ones and you should brake straight.
Old Jan 9, 2008 | 01:30 PM
Animalistic's Avatar
Animalistic
Those calipers are quite easy to rebuild. The O-rings are cheap. It takes more time than anything else. If you have air tools, go for it. If not, replace them as you will never get the piston out of the caliper without air. You can do it by pressing on the brake pedal with the caliper out but you stand the chance of damaging the master cylinder and brake line so don't do it. My local NAPA has reman calipers for about $40.00. Pop them in, bleed the system and you are good to go. Just don't let the master cylinder run dry.
Old Jan 9, 2008 | 03:21 PM
toolbeltdiva
Thanks for your help, I think I will just go ahead and replace them probalby easier it seems.
Thanks again
Old Jan 9, 2008 | 03:25 PM
currituckF150's Avatar
currituckF150
Thanks again
Don't forget to replace the hardware & lubricate slides
sand_fiend
Jan 23, 2013 10:33 AM
DemonRace6
15
Apr 20, 2011 01:34 PM
Daviddc114
Aug 30, 2008 03:06 AM
Hank85713
2004 - 2008 F150
Nov 10, 2004 02:36 PM
rogerwa
Jun 11, 2003 09:18 AM
