Light switch knob removal
Old Jan 8, 2008 | 03:42 PM
silentrunning's Avatar
silentrunning
Light switch **** removal
I have the new instrument bezel for my 1992 F-150 and have it all ready to put on. My problem is that I can't figure out how to remove the light switch ****. The **** is too large to go through the hole. Any help will be appreciated.
Doug
Old Jan 8, 2008 | 03:48 PM
95F350XL's Avatar
95F350XL
There is a little spot you stick a screw driver in and push a tap that will release the **** from the switch.
Old Jan 8, 2008 | 03:51 PM
Virto's Avatar
Virto
Some are harder to get off than others.
It's got a triangle shaped pressure clip that holds the **** on. The objective is to use a tiny screwdriver or pick to open it slightly and let the **** slide off.
When I took the one off on my current truck this last weekend, I didn't make a clean contact with the clip and cracked the pull's shaft, but it slid off the clip. Press it back on firmly, seems just fine, but of course I KNOW it's cracked under there.
There's an article under instrument panel mods for installing a factory tach in a bronco. There's a little picture of the clip in there.
https://www.ford-trucks.com/article/...Or_Bronco.html
Old Jan 8, 2008 | 03:52 PM
tomtoc's Avatar
tomtoc
pull light switch all the way out
put little screwdriver in the slip
pull the screwdriver tip toward you, putting pressure on the little spring clip that holds onto the metal center.
pull real hard at the same time on the switch. once it's off, you'll see.
Old Jan 8, 2008 | 03:53 PM
silentrunning
Thanks Chris, All the plastic on my truck is so brittle from the Florida sun I though I better find the correct way rather than start horsing around. I appreciate the info.
Doug
Old Jan 8, 2008 | 05:27 PM
lostin90s's Avatar
lostin90s
Even in PA half the truck I get parts off of r glued on. The clip goes bad. I keep extras in my stash.
Old Jan 8, 2008 | 06:38 PM
silentrunning
Thanks guys. It came right off with a little screw driver. Piece of cake.
Doug
Old Jan 8, 2008 | 06:44 PM
95F350XL's Avatar
95F350XL
Nice I need to get the little part that snaps on the end of the shifter. Mine fell off and I used some silicone. But I was playing with it one day in traffic and I pulled it off, now I got to clean out the silicone and stick it back on lol.
Old Jan 8, 2008 | 07:26 PM
brown 4x4's Avatar
brown 4x4
Windshield urethane will glue it on forever if you can find some.
As for the light ****, I found out on my 97 F-250 mine had been glued (superglue?) back on by the PO. The only way to get it off was to break it. I got a new one from Ford and it came with the shaft going in to the light switch. But there's no possible way to reach the switch to remove the **** with the shaft like the older trucks, is there? In my case, it was worth buying a new ****. I had to pull the cluster to clean it as I can't stand a dusty cluster in an otherwise clean truck.
ERG4Life
15
Mar 17, 2024 11:25 AM
DaveF-250SD
Nov 15, 2015 12:26 AM
atomicjoe23
28
Jul 12, 2015 06:52 PM
Shadowrider123
Dec 6, 2014 08:05 AM
