750cfm.. more or less??
Old Sep 26, 2002 | 04:47 AM
DeenHylton's Avatar
DeenHylton
>oh, ive been thinkin about ordering that 514 crank out of
>summit and doin that next summer... let me get this
>straight.. ill keep the 429 rods and get 460 pistons right?
>ill probably bore it about .30 over to...
I'd check with Summit...but I believe they use the 6.135" big-block C***
rod. Most stroker kits use a off-set ground crank where the rod-journal diameter has been reduced from the stock ford 2.5" down to a stock c*** diameter of 2.2"
That is a good thing as your less likley to spin a rod bearing at higher RPM's as your bearing diameter gets smaller (less drag/friction/heat). Also some 514 kits require a .080 over piston to achieve the 514 c.i. which means sonic checking engine blocks till you find one that will safely overbore that much. You should be able to find shops that sonic check for around $100-150 a block. Deen
Old Sep 27, 2002 | 05:51 PM
gray79f250's Avatar
gray79f250
bigred460
30
Jan 2, 2007 02:24 AM
Bob_1
15
Sep 19, 2006 11:35 PM
67blueford
Mar 24, 2004 10:14 AM
maxcanine
Apr 14, 2003 09:37 PM
crewcab74
Mar 7, 2001 11:48 AM
