Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Check Engine Light
Old Jan 8, 2008 | 01:04 PM
LostMayhem's Avatar
LostMayhem
Check Engine Light
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have a 2002 Lightning that has the check engine light on because of the air raid intake i have in it. I took it to the dealer and they said the light is going off because the engine is running to lean. Could this be bad on the engine if i leave it? I also have flowmaster exhaust on it and i dont know if that could be setting the light off also. Any help on this would be nice, thanks.
</TD></TR></TBODY></TABLE>
Old Jan 8, 2008 | 01:08 PM
antony25's Avatar
antony25
possible oil and dirt on the mass air sensor. these type of air filters let alot of dirt in.
Old Jan 8, 2008 | 01:10 PM
MisterCMK's Avatar
MisterCMK
Lets back up a second here. What is the actual code that is being set?
Old Jan 8, 2008 | 03:48 PM
Stewart_H's Avatar
Stewart_H
Yep. Scan it and post the actual DTC.
Stewart
Old Jan 8, 2008 | 07:03 PM
LostMayhem's Avatar
LostMayhem
It recieved codes P0171, P0174, P1229 Lean on banks 1 and 2. Im not sure what all of that means I would appretiate some help.
Old Jan 8, 2008 | 07:17 PM
MisterCMK's Avatar
MisterCMK
P1229 Supercharger Intercooler Pump Not Working (Ford)
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
I would start by looking at the intercooler pump.
Old Jan 9, 2008 | 12:17 AM
Stewart_H's Avatar
Stewart_H
Check and recheck all your vacuum lines to make sure they are in good shape and are still properly connected.
Is your MAF housing seated and sealed properly on the Air Raid housing?
If, when you check your IC pump you find it isn't working, take it out and clean it. A lot of guys have had good luck by cleaning the gunk from the pump.
Stewart
clouden
May 2, 2011 12:05 AM
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
mjorda2
Electrical Systems/Wiring
Dec 13, 2007 12:00 AM
kdc642
1997 - 2003 F150
Nov 30, 2007 08:34 AM
brianstacy
Apr 16, 2007 11:25 PM
