oil pump?
Old May 12, 2005 | 12:16 AM
ford390gashog's Avatar
ford390gashog
oil pump?
which type of oil pump should i buy a stock one, high volume or high volume high pressure i will be running a 10 quart pan so which one should i buy.
Old May 12, 2005 | 12:34 AM
FERacing66's Avatar
FERacing66
Ill vote for the High Volume, high pressure is unsutied for street applications. Make sure its a Melling HV oil pump and get the hardened shaft. I run the Melling HV oil pump in my FE with stock pan, but I also run 6.5 quarts to ensure the pickup stays covered if the oil sloshes on a hard lanch.
Why are you replacing the oil pump?
Old May 12, 2005 | 12:39 AM
ford390gashog
i am replacing the oil pump because i removed it to install a new ft oil pan 10 qts compared to the stock 5 on my fe and upon opening it there is a fracture running through the housing looks like a poorly made pump guess you get what you pay for i believe it is a clevite brand
Old May 12, 2005 | 12:43 AM
KenB's Avatar
KenB
If this engine is for 'normal' street use, not taking it to the track, etc. I'd say a stock oil pump will do just fine.
Has the engine been rebuilt or are you doing this now?
I ask because-
As important as the pump is making certain the oil can return to the pan as quickly as possible. Making sure the oil drain ports are really clean, maybe even grinding them out a bit.
Old May 12, 2005 | 12:52 AM
ford390gashog
yes the engine has about 25,000 on it yes it will be for stock use ican get a stock pump for 25.00 or a hv/hp for 45.00 i have not done the oil mods either.
Old May 12, 2005 | 01:17 AM
FERacing66's Avatar
FERacing66
I agree a stock pump will be fine most of the time. But FE's have a known oil defficeny issue, and the HV oil pump helps to alleivate the problem. Make sure you get a good oil pump, it is one of the most critical parts of the engine. Good thing you caught the cracked oil pump before it failed and killed your engine.
Old May 12, 2005 | 01:43 AM
ford390gashog
sounds good i will go with a good stock pump
Old May 12, 2005 | 04:05 AM
stegmst's Avatar
stegmst
I was thinking about switching back to stock pump. I have a high volume pump and I am having issues with valve covers filling with oil. I still have to pull my rocker arms off to make sure everything is okay with them. But I have to decide if I am going to ditch this HV pump before I put my pan back on. A couple of different engine builder I have talked to say all they run is HV. So I am a little undecided on what to do. I dont want to take the pan off again to swap pump out if everything else checks out.
Old May 12, 2005 | 04:40 AM
ford390gashog
sounds like a worn out top end valve train i went to adjustable just because of that
Old May 12, 2005 | 08:53 AM
stegmst's Avatar
stegmst
What brand did you end up going with?
Old May 12, 2005 | 11:29 AM
ford390gashog
i went with the stock ford fe adjustavle ones
Old May 12, 2005 | 12:42 PM
rusty70f100's Avatar
rusty70f100
It may be a little late, but I vote HV, with some conditions. Those are, that you run an ARP drive shaft, and your rocker arm assembly is in good shape. This you can tell by your oil pressure. If it's below about 15psi at idle, they're probably getting worn out. Without a restrictor in the heads, you'll get too much oil up in the valve covers, which can lead to smoking, leaking, and pinging if too much gets into the combustion chambers.
Old May 12, 2005 | 02:42 PM
stegmst's Avatar
stegmst
I have the restrictors and I get about 20psi hot idle.
Old May 12, 2005 | 02:44 PM
ford390gashog
well i bought the holly number 90 main jets so do i just put one in each oil feed hole in the heads and put the bolt on top or am i missing something here
Old May 12, 2005 | 02:48 PM
rusty70f100
Yep just drop 'em in.
