Transmission Problem
Old Jan 8, 2008 | 11:26 AM
fstowe's Avatar
fstowe
Unhappy Transmission Problem
The transmission in my 2002 explorer was recently replaced with a re-man. Since the work was done, it feels like the auto 4x4 kicks in when turning slowly. It is more noticeable when vehicle is hot. The ford dealer that did the trans replacement swears nothing is wrong. Also, I've noticed a decrease in gas mileage. This leads me to believe auto 4x4 is kicking in when not needed. What is the problem?
Old Jan 8, 2008 | 11:59 AM
ripcurl94's Avatar
ripcurl94
Might take it somewhere else and get it checked out .. then take the results back to the dealer.. if the results are bad.. when you turn the car slowly, if its in 4x4.. you would def be able to tell..
Old Jan 10, 2008 | 10:31 PM
ford trans tech's Avatar
ford trans tech
is it an all wheel drive vehicle , and are all of the tires the same size and amount of wear
Old Jan 10, 2008 | 10:32 PM
ford trans tech
by the way no matter which all wheel or 4 wheel drive the transfer case and its electronic controls are completely seperate from the transmission
Scott Schoenleben
Feb 14, 2016 01:05 PM
stoven
Apr 22, 2014 08:48 AM
hornsurgeon
1997 - 2003 F150
Dec 3, 2012 07:34 AM
Fordfanz
Oct 4, 2004 02:52 PM
97GreenRanger
Mar 23, 2004 07:22 PM
