DP Tuner Question
Old Jan 8, 2008 | 09:51 AM
Paul Moody's Avatar
Paul Moody
DP Tuner Question
I know you guy's recommend staying under 2000 RPM's for best fuel economy. I have a stock truck except for 6637 mod. I can stay under 2000 RPM on acceleration if I go slow but will about get run over in most locations getting up to highway speeds that way. I'm not one that needs to be put back in the seat at every start but I don't like to be the slug at the front of the line. My question is after the Guages, DP Tuner and 4"Exhaust, will I have alot better acceleration at these lower RPM's or will it still be hard to stay in that range? Does the chip give you faster jump to higher RPM's of more HP at lower RPM's or both?
Thanks,
Paul
Old Jan 8, 2008 | 10:03 AM
That_Guy's Avatar
That_Guy
Thanks,
Paul
I find that you can either punch it and throw yourself back in the seat and break the back tires loose, or you can accelerate just as slow as stock. It all depends on how you drive. There is more power through all the RPMs
Old Jan 8, 2008 | 10:06 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
No need to stay at 2000 rpm when getting to speed. Put the hammer down and get to speed. You will have better throttle response with the tuner and will be much faster to get to speed.
No way I can stay at 2000 rpm all the time. Way to much fun to play than worry about mpg.
Old Jan 8, 2008 | 10:07 AM
Pocket's Avatar
Pocket
With a chip it's easier to stay under 2K RPM's when accelerating, unless your torque converter is weak.... but that's a different story.
Taking off from a light or stop sign is only a small part of driving. The 2K RPM "limit" is for cruising down the road. Go over 2K RPM's, and the fuel mileage drops quickly. Depending on your speed limits in your state, you may or may not have an easy time of keeping the RPM's low. Interstate highways here in Colorado can go up to 75 MPH. Go slower than that and I'll get run over, so keeping my truck under 2K RPM's in those situations isn't always the safest bet. I'd rather keep up with the flow of traffic.
Also with gauges, you can monitor boost and EGT's. Rule of thumb when driving for MPG's: accelerating, crusing, etc is to try and keep RPM's below 2K, EGT's around 600 degrees or less, and boost at 5 lbs or less. You're going to surpass that all the time when taking off from a stop light, but once you are up to speed try monitoring those three things to help with fuel economy.
