Aerostar Ford Aerostar
Overdrive quit working
Old Jan 7, 2008 | 11:46 PM
Bax2008's Avatar
Bax2008
Question Overdrive quit working
1995 XLT 3.0L
No warning signs.
From one day to the next, no OD.
When selecting OD, it feels like it is staying in 3rd and refuses to upshift, even at highway speeds.
Gears 1-3 & R are solid.
What should I be checking?
Old Jan 8, 2008 | 12:41 AM
Bear River's Avatar
Bear River
Former ******
OD is engaged electronically, so the main things to look for is either that the computer is not seeing the signals needed to engage OD, or that the solenoids involved are not functioning correctly.
Possible culprits include the vehicle speed sensors, a computer fault that triggers open loop mode, or several other similar problems.
Old Jan 8, 2008 | 12:48 AM
Pablo-UA's Avatar
Pablo-UA
Check OD shift solenoid resistance, wiering, pull codes to be sure it is ok.
If you are sure OD solenoid is good, try to ajust OD band.
Old Jan 8, 2008 | 03:04 AM
xlt4wd90's Avatar
xlt4wd90
Are you getting any warning lights on the instrument panel? Are all the brake light bulbs working? A failed bulb will cause all sorts of things to stop working, including the rear ABS, transmission lock up, and cruise control. (and 4wd if you have that)
Old Jan 8, 2008 | 10:10 AM
copper_90680's Avatar
copper_90680
Hi Bax2008,
Welcome to our FTE forum
There are only 2 solenoids on the 95 A4LD. One is for the 3-4 shift and one is for the Torque Converter lockup. I don't know if the Overdrive is controlled by any of these. I'd have to check the manual after I get home to be sure.
From a complete stop you should feel the following 4 slight jolts:
1-2
2-3
3-4
T/C lockup (about 40-45 mph)
If you are missing the last jolt, it could be either one of the solenoids.
Come to think of it, you should feel all 4 jolts regardless of whether you are in D or OD, so what you are describing may not have anything to do with O/D.
Old Jan 8, 2008 | 11:22 AM
Bax2008's Avatar
Bax2008
I'll check the wiring this afternoon. Thnx.
I read somewhere that the TPS is often the culprit. Opinions?
Old Jan 8, 2008 | 11:25 AM
Bax2008's Avatar
Bax2008
No warning lights.
I'll check the bulbs later today. (that's a weird one)
On that note, just recently, my radio lights flash when my left turn signal is on (without the headlights being on).
Thnx.
Old Jan 8, 2008 | 01:02 PM
eehoepp's Avatar
eehoepp
Check all the fuses - even the ones that don't seem related.
I recently had the speedo quit on my 95 3.0 XLT, and at the same time it stopped shifting into OD. Turned out to be a blown fuse for the interior lights...
The VSS system was powered off the same fuse as the interior lights (which I believe includes the instrument panel & radio lamps). A broken wire on the front passenger door light switch blew the fuse, which killed power to the VSS & the speedo.
The flashing radio light with turn signal sounds like a dead circuit being back-fed through a bulb.
Good luck with your troubleshooting.
Cheers,
Eric
Old Jan 8, 2008 | 02:59 PM
96_4wdr's Avatar
96_4wdr
any codes?
pull your own click
many ECU error codes prevent OD and TC lockup.
TPS problems usually show up as an intermittent due to the type of sensor it is. is your problem intermittent? TPS can cause OD or TC shift problems but look for more obvious higher percentage problems first
the stop lights provide a switched ground to the speed control unit logic which can effect OD and TC LU shifting
from Serv Manual
Pressing OFF turns off the system [grounds 151 (LB/BK) wire]. The system is also turned off when the brake pedal is depressed [removing the ground provided by the Stop Lamps through the 810 (R/LG) wire] or the Ignition Switch is turned OFF. The Vacuum Dump Valve also operates when the brake pedal is depressed. This is a backup device to release the servo.
operating an A4LD with no TC lockup will kill the tranny in a couple hundred miles from overheating
the guys have gave you a good list above
Old Jan 8, 2008 | 06:51 PM
Bax2008's Avatar
Bax2008
Cheers,
Eric
Thnx for the reply.
I checked all fuses in the fuse panel and they all seem fine.
Are there any fuses OUTSIDE the panel that should be checked?
I'll be trying to find the time tomorrow to climb underneath and check the OD wiring harness and connection at the transmission.
Old Jan 8, 2008 | 06:58 PM
Bax2008's Avatar
Bax2008
Originally Posted by 96_4wdr
any codes?
pull your own click
from Serv Manual
Thnx for the reply.
I'll check for the codes ASAP.
No, the problem does not appear to be intermittent. She does not want to shift into 4th. Period. Revs/engine noise at highway speeds are annoyingly high.
Forgot to check the brake lights today. Will check first thing tomorrow.
No OFF switch on this one. OD is on the column.
Good bunch on this forum. I'm lucky I found it.
Old Jan 8, 2008 | 07:15 PM
Bax2008's Avatar
Bax2008
I checked the brake lights just now. They are fine.
Thnx
Old Jan 8, 2008 | 09:19 PM
96_4wdr's Avatar
96_4wdr
PCM will prevent OD and TC LU if the thermostat fails open, is your temp gauge reading where it usually does?
if ECT or IAT fail, can also prevent OD and LU
Old Jan 8, 2008 | 09:55 PM
Bax2008's Avatar
Bax2008
Thnx for the response.
Temp is reading fine.
T-stat and both temp sensors have been replaced within the last year.
Old Jan 9, 2008 | 01:45 AM
TheHandyman's Avatar
TheHandyman
A Few Ideas...
You're having electrical probs with that wierd turn signal/ radio light deal (& switch wire blowing fuse prob).
I'd guess that was separate from your OD prob since signals on '95 use separate bulbs from brake lights. Otherwise they'd be connected. May still be connected especially if they began about the same time.
I think Copper mis-spoke because 3-4 shift IS the same as 3-OD. 4th gear is an overdrive ratio I believe. After that the torque converter should lock up.
Of course there's the possibility of mechanical failure.
