Sponsored by: Real Truck
power steering fluid
Old Jan 7, 2008 | 08:51 PM
possum0208's Avatar
possum0208
Cool power steering fluid
I have a 2006 f-250 It has metal shavings in power steering fluid. Has anyone else had this problem?
Old Jan 7, 2008 | 08:54 PM
msgtg's Avatar
msgtg
Nope...that's a new one! How did you discover the shavings?
Joe
Old Jan 7, 2008 | 09:08 PM
possum0208's Avatar
possum0208
it got hard to turn. This is the second time this has happened. The first time they replaced the brake booster
Old Jan 7, 2008 | 09:42 PM
zrt600guy's Avatar
zrt600guy
Can you actually see thin shavings, or just very fine particles? And you were able to see them by just opening up the ps cap? Have you flushed the system and filtered them out? 80k on a '05 and just recently flushed ps with no problems. Good luck!
Old Jan 7, 2008 | 09:46 PM
possum0208's Avatar
possum0208
Just matal particals. They were supossed to have flused the system when they replaced the brake booster
Old Jan 8, 2008 | 05:15 AM
msgtg's Avatar
msgtg
Bummer Dude! Who did the work? A dealership should be willing to help if they screwed the pooch to begin with.
Joe
Old Jan 8, 2008 | 11:39 AM
FloridaF250's Avatar
FloridaF250
My fluid seems to be low. it's barely on the stick when checking - do you just add regular power steering fluid to it or is it special?
Old Jan 8, 2008 | 11:52 AM
dagren99's Avatar
dagren99
PS Fluid
Takes Auto Trans Fluid - Mercon
DG
Old Jan 8, 2008 | 03:52 PM
zrt600guy's Avatar
zrt600guy
I use Mobil Synthetic ATF with good results. '05 F250 Hopefully a verified flush will do the trick. Good luck!
Old Jan 8, 2008 | 04:48 PM
miker67's Avatar
miker67
You should flush it and install a filter into the return line.
DeanBob
Mar 4, 2013 06:30 PM
berry1234
2004 - 2008 F150
Jun 12, 2012 02:19 PM
Beaned
Aerostar
28
Sep 14, 2008 10:47 PM
Bob Crain
May 19, 2005 04:59 PM
MJW
Mar 26, 2004 10:17 AM
