I currently building a 514 engine and dont know what cam to use
The engine is has 11.8 compression and has DOVE-C heads for it that are stock and roller rockers and a weiland stealth intake and I'm going to run a 3000 stall converter
The truck is being built for stock truck pulls and will run on the street to and it has 4.56 gears in it and 36" tires for street and 33" tires to pull with
