HELP!!..check engine-dtc-code P132B.from my sct street program.
Old Mar 21, 2007 | 09:33 PM
mrholmes's Avatar
mrholmes
help...i got a check engine light--after programing my 6.o with my sct on street file and driving it 200 hundred miles the code came up--- p132b---what does that code mean..so i hooked back up the sct and erased the code and then put it back to stock...also ..do i really have to disconect the fuel pump and electric fan fuses...found the fuel pump fuse..but the electric fan fuses? all i found close to that was a 10amp eatc module/front blower relay coil and a 40 amp front blower motor..are those the ones?
thanks
tim
Old Mar 21, 2007 | 09:51 PM
XHunter's Avatar
XHunter
are you sure it is P132B????
P0132 is "O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)"
double check the code...?
Old Mar 21, 2007 | 09:55 PM
mrholmes's Avatar
mrholmes
yes it was p132b..and the check engine light was on..
Old Mar 21, 2007 | 11:11 PM
wb6anp's Avatar
wb6anp
Check out this tsb for that code. It is for the turbo. https://www.ford-trucks.com/tsb/full...hp?tsb=06-24-6
Old Mar 22, 2007 | 08:10 AM
03f2506.0's Avatar
03f2506.0
wb6 is right. It's turbo related. When I had that code the dealer had to replace my turbo for the 2nd time
Old May 3, 2011 | 04:24 PM
johnnybgood1991's Avatar
johnnybgood1991
i have a 03 f25 6.0 and it has the same code P132B but the light isnt on. what was wrong with the turbo? im new to this
aparrothead
Mar 16, 2014 09:17 PM
Tom Watt
6.4L Power Stroke Diesel
Aug 12, 2009 07:00 AM
wreedZ71
2004 - 2008 F150
15
May 14, 2009 07:33 AM
savage2211
Ride Of The Week
Mar 8, 2009 06:52 PM
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
