HELP!! Urgent!
Old Jan 6, 2008 | 07:32 PM
F350-6's Avatar
F350-6
Well I don't know where Pop went but my 02 manual says fuse #19 is Body Security Module/4x4 Module so I'm guessing that's not it.
Looking at 10 amp fuses #35 says Instrument cluster and #41 says Instrument Cluster. Maybe it's one of those.
Edit: I guess I type too slow. I see you've already got it figured out. Glad to hear it.
Old Jan 6, 2008 | 07:34 PM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by miker67
Well gents, I had him go back and check ALL the ten amp fuses in the panel and sure's shootin, there was one blown. He stuck a replacement in there and he is back in business. He is gonna stop at a service station and get some additional fuses in case it happens again on the way home, and tomorrow we will delve into it when he comes into work to see if there is any specific reason it blew. THANKS SO MUCH to all the quick posters. That saved me a TON of time and made my driver's evening so much better.
glad you got it....
Old Jan 6, 2008 | 07:39 PM
miker67's Avatar
miker67
He didn't tell me which one it was, but he said it was labeled "ignition Switch"
Old Jan 6, 2008 | 07:59 PM
SpringerPop's Avatar
SpringerPop
My fuse 19 is labeled:
Auxilliary Powertrain Control Module
(APCM) (Diesel only), Instrument Cluster,
GEM Module, Overdrive Cancel Switch, Idle
Validation Switch (Diesel only), Overhead
Console, Diesel PCM via Clutch
Pop
Old Jan 6, 2008 | 08:01 PM
SpringerPop
Though is CERTAINLY does not enter into the equation when getting help around here, maybe it's time to consider becoming a Supporter? Entry into that club is really cheap!!
Pop
Old Jan 6, 2008 | 08:21 PM
F350-6's Avatar
F350-6
Pop
This was a good catch, but no points for you tonight. I have to spread them around apparently.
Ford must have had budget cuts because my 02 manual is nowhere near that descriptive. As stated earlier we simply have 2 different fuses labeled Instrument Cluster. The only (Diesel Only) item we show is #303 IDM relay.
