Air Intake system
Old Jan 6, 2008 | 08:41 PM
a-rod's Avatar
a-rod
Air Intake system
So Im a new 7.3 owner but I have read enough in the past to determine that the stock air intake setup is pretty much garbage. Well I have a complete 6.0 liter air intake sytem and I remember reading about some of you guys installing these on the 7.3s. Is this a good route to go?? Or should I just do the 6637 mod?? Thanks
Old Jan 6, 2008 | 08:47 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
well AIS which is 7.3 version of stock 6.0 intake is great if you dont turn it up. once you start putting power hungry stuff on AIS is not enough. get 6637 if you like a little more turbo nois , and get AIS if you will keep the truck the way it is.
i know the filter that you have from 6.0 is perfect if you get it to fit in 7.3. i think you have to move battery in oposite dir and compleetly remove stock air box, which is Garbage just like you heard.....
good luck with your new truck
