Sponsored by: Real Truck
Help with differential Identification
Old Jan 6, 2008 | 03:38 PM
S.D.F250's Avatar
S.D.F250
Alright ladies and gents. I need some help with the identification of my front and rear diffs. I am going to try and attach some photo bucket links. I hope this works. The reason I want to know what I have is so that I can lower my gears and add lockers. Any all info is appreciated.
http://i5.photobucket.com/albums/y16...P/100_3834.jpg
http://i5.photobucket.com/albums/y16...P/100_3826.jpg
http://i5.photobucket.com/albums/y16...P/100_3829.jpg
http://i5.photobucket.com/albums/y16...P/100_3828.jpg
http://i5.photobucket.com/albums/y16...P/100_3827.jpg
http://i5.photobucket.com/albums/y16...P/100_3825.jpg
Old Jan 6, 2008 | 03:53 PM
boxcar1974's Avatar
boxcar1974
What you need to do is look in the door jamb area and look for a factory tag with all the info on it. There is a spot that says axel with a code. Then match it up here:
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
Old Jan 6, 2008 | 04:36 PM
S.D.F250's Avatar
S.D.F250
Mine says it's a 31 (— 3.73 non-limited slip, F-250/Excursion) Wich takes care of what gears I have, but how do I find out what kind of Axle I have?
Old Jan 6, 2008 | 04:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
You have a Visteon (or Sterling) 10.5 inch differential in the rear and a DANA 50 in the front.
Old Jan 6, 2008 | 05:09 PM
Citypol86's Avatar
Citypol86
I have an '05 F250 SD Crew Cab 5.4 with the axle code of "37". It's clearly a seven and not a one also. The sticker's nice and clean. Any ideas?
Later...
Brewster...
Old Jan 6, 2008 | 05:14 PM
antony25's Avatar
antony25
the tag on the rear axle will show ring gear size and axle ratio. example- 3L73 1025 for a 10.25" with 373 gears and a posi
Old Jan 6, 2008 | 06:14 PM
boxcar1974's Avatar
boxcar1974
Later...
Brewster...
What I posted was for 99-04 trucks.
Not sure about the 05+ trucks. But you alsways could crawl underneath and see. The sticker should still be there. Mine is on my 03' with 90K miles on it.
Old Jan 6, 2008 | 07:30 PM
walleyeman's Avatar
walleyeman
A 37 is a 3.73 non-limited slip. I know only because i had to research mine.
