roller conversion question
Old Jan 9, 2008 | 05:43 PM
reed1951's Avatar
reed1951
Wait, I have an 87 302 truck block behind my garage!! It was flat tappet from the factory but from what I've read...Could I get some OEM roller lifters cheap, and a used spider bar assembly off of ebay and a used roller cam and it work without all the hassel of special pushrods and clearancing stuff (I would be using after market heads with the engine)
Old Jan 9, 2008 | 08:28 PM
baddad457's Avatar
baddad457
If it's an 87 block it should be a roller. Look at the casting numbers, should be either E6SE or E7TE. The lifter valley will have two raised bosses above the #'s 2 & 4 cam journals. These may or may not be drilled and tapped for the spyder hold down bolts. If you have these drilled and don't want to damage the cam bearings, watch the depth on drilling. If replacing the bearings, don't sweat damaging them.
Old Jan 9, 2008 | 08:46 PM
reed1951's Avatar
reed1951
so would I be able to use stock style roller lifters no prob?
Old Jan 9, 2008 | 08:52 PM
baddad457's Avatar
baddad457
Yea. All the factory roller stuff will work.
Old Jan 9, 2008 | 09:07 PM
reed1951's Avatar
reed1951
thats sweet!! I just went out side to check for the bosses and it has them. So I can get a used spiderf assembly, get some oem roller lifters from summit pretty cheap, and a used roller cam and I'm on my way right? Boy that sure beats paying 400 or more for retro lifters and 200 for retro cam pushrods etc.
Old Jan 9, 2008 | 09:19 PM
baddad457's Avatar
baddad457
Yea, that's why it's cheaper to start with a roller block. You can pickup used B303 cams over on Stangnet.com for $50 occasionally. I bought a new second hand Z303 for my 331 there for $115 shipped. There's always someone selling new or little used roller stuff there cheap. If you'll eventually want to get into serious roller performance, might be better to buy a set of Crane's O.E. replacement roller lifters. These are what I run with my Canfield heads on the 331 and on a previous 302 build. Good for 7500 rpms vs about 6500 for the Ford rollers.
Reconor
Sep 15, 2016 09:49 AM
85lebaront2
Mar 12, 2014 05:51 PM
Ringo Fonebone
Jun 10, 2004 07:17 PM
scott9320
Mar 25, 2003 10:25 PM
BigJake86
Mar 15, 2003 08:26 AM
