300 hp 5.0
Old Jan 9, 2008 | 09:58 AM
Hillcapper's Avatar
Hillcapper
300 hp 5.0
OK, need some more opinions. I'm going to be replacing my 4.9 6 cyl with a 5.0 EFI out of a 92-96 truck. I already plan on doing some engine work, cam, rod and main bearings etc.. Whats the general HP rating on these engines stock? What do I need to do to get it up to around 300 hp, without a bottle? How radical (and expensive) will I have to get?
Thanks
Old Jan 9, 2008 | 10:55 AM
Kemicalburns's Avatar
Kemicalburns
is this for a 4wd or 2wd, what will you be using the vehicle for? are you set on the 302?
Old Jan 9, 2008 | 02:16 PM
Hillcapper's Avatar
Hillcapper
Pretty much set on the 302 unless I can find a 5.8 at a reasonable price. Its for a 94 F150 shortbed. No towing or hauling to speak of. 5 speed.
Thanks
Old Jan 9, 2008 | 03:06 PM
Kemicalburns
only reason i meantioned going 5.8 is the power comes much cheaper to reach your goal. and is the same amount of work involved since you basicly are removing everything related to the 300-6
Old Jan 9, 2008 | 08:33 PM
baddad457's Avatar
baddad457
On a stock 94-97 shortblock, all you need is better heads. The Explorer 5.0 was rated at 210 hp with the same shortblock topped with GT40P heads. Upgrade to something like AFR165's or similar and you'll get 300 hp without trying with the stock roller cam.
Old Jan 9, 2008 | 10:01 PM
HemiEater's Avatar
HemiEater
if you do reach the 300 mark...put some gears in it, 4.10 anyways.
Old Jan 9, 2008 | 11:20 PM
Conanski's Avatar
Conanski
Ported stock heads like the Thumper E7's and a bit more than the HO cam will get you 300+ crank HP.. assuming the induction and exhaust system can support it as well. AFR claims the 165 heads with 1.7 rockers, carb, and longtubes made 400hp on an otherwire stock 5.0HO. http://airflowresearch.com/articles/article087/A-P1.htm You'll notice that peak occurs at just over 6000rpm.
Old Jan 10, 2008 | 08:21 AM
Hillcapper's Avatar
Hillcapper
Thanks everyone, I'll do some research on heads. I've also have a friend that builds dirt track engines (chevys though) and see what he says. I will be changing my rear gear, its a 2.73 now!
Old Jan 10, 2008 | 09:59 AM
Kemicalburns
becareful getting advice from a chevy builder, we have seen a few of these go bad on this forum.
good luck and keep us posted
Old Jan 10, 2008 | 03:07 PM
HemiEater's Avatar
HemiEater
that would be the first thing I would do....but thats me...
FordFriend150
23
Sep 25, 2025 07:36 AM
88f150 on 35s
Apr 11, 2024 11:37 PM
Power_lineman11
6.4L Power Stroke Diesel
Apr 6, 2015 08:05 PM
ernesteugene
19
Apr 25, 2009 01:18 PM
mauicruza
Jan 24, 2006 05:27 PM
